Swapping a 94+ console into my 93
Yes, I have searched, but didn't get an answer.
I have removed the console from my 93 to swap it with a 95, but it looks like I will have to swap the E-brake cables as well as come up with a way to mount the E-brake handle. Has anyone done this mod to their lude yet? What exactly has to be done?
i've done this, it wasn't easy but worth of it
93 console sucks!
u don't have to swap the E-brake cables, just make an extension to part on e-brake which holds cables and weld it to e-brake.
To mount e-brake i welded two bolts to the car, finding best position is the worst thing.
93 console sucks!u don't have to swap the E-brake cables, just make an extension to part on e-brake which holds cables and weld it to e-brake.
so how did you go about finding the right position? i'm doing this mod as we speak. do you have measurements of your mounting spots for the e-brake? i plan to just drill holes into the car and screw the bolts into the spot. until i get it fixed i have no e-brake. the console and cupholder are worth it for the time being.
I'm actually looking it at it. the e-brake cables are coming out of a hole directly behind the '93 e-brake. If i move the '93 ebrake over, the cables would be coming in at an angle which couldn't mean anything good. I know you said you welded a piece of metal to extend like an arm to hold the cables but now?
this would be a great write up.
This guy just did it, says to PM him if anyone wants/needs help.
http://www.hpoa.org/showthread...=9728
is there not a way to get longer e-brake cables and replace the ones being used in the '92-93? I figured that would solve part of the problem
tonychony
Feb 13, 2008 04:24 AM
