Car wont start. "AGAIN"!!!!
Old Feb 4, 2003 | 07:30 PM
BLuDoHcReX's Avatar
Default Car wont start. "AGAIN"!!!!
ok once again. I have an 88 crx si with a stock engine. It wont start. I was driving and it just "DIED" on me. it bogged out. starter is fine, gas is fine, its getting fuel, distributor is fine. anything else ANYONE reccomends to check? someone said to check the main relay. im gonna check that tomorrow morning but besides that anything else? '' HELP ''
Old Feb 4, 2003 | 09:56 PM
kim_2_da_chee's Avatar
Default Re: Car wont start. "AGAIN"!!!! (BLuDoHcReX)
all i can say is that it is definately an electrical problem.
i guess it could be the main relay. are u sure u fixed ur dizzy?
i had the same problem, and it was just the rotor screw in the dizzy that broke and fell off.. just replace it and it should run fine.
good luck
Old Feb 4, 2003 | 09:59 PM
BLuDoHcReX's Avatar
Default Re: Car wont start. "AGAIN"!!!! (kim_2_da_chee)
ya the dizzy is fine. the car just keeps turning over but it wont start. im wondering what else it could be
Old Feb 4, 2003 | 10:11 PM
Camshaft's Avatar
Distributor is fine ? how did you check it ?
Are you getting spark from the plug wires ?
Is your Check engine light coming on when you turn the ignition key on.
Does your ECU show any codes
Timing belt ? Does it crank over fast ?
Have some one look in where the oil cap is and see if the top end is turning
Could be main relay but never seen one fail driving
Sounds more like distiributor or ignitor problem
have fun
later
Old Feb 4, 2003 | 10:54 PM
aVstAr's Avatar
Default Re: Car wont start. "AGAIN"!!!! (Camshaft)
if for instance there is no spark at the wires, would you lose comp when checkin it? waht would this problem be?
Old Feb 4, 2003 | 10:58 PM
Camshaft's Avatar
Default Re: Car wont start. "AGAIN"!!!! (avscrx)
HUH ?
What the heck to you mean lose comp (compression) when checking what where when how ??
Compression is static it doesn't change, unless something is wrong.
Broken Timing belt etc....
You have to explain yourself more avscrx
Old Feb 5, 2003 | 06:38 AM
BLuDoHcReX's Avatar
I will check ALL of that stuff and then I will get back to you. I checked the fuses too. they all seem to be fine. and the distributor I took it off and I put another one on there and the car still didn't start. the dizzy I put on is fine cause its on my friends car right now. so im gonna check that other stuff.
Old Feb 5, 2003 | 06:42 AM
Camshaft's Avatar
but you haven't checked spark yet ?
Coming of the the distributor
Old Feb 5, 2003 | 06:48 AM
BLuDoHcReX's Avatar
no I haven't. I will check though. I just need to charge my battery.
Old Feb 5, 2003 | 07:55 AM
McD's Avatar
McD
It's probably your main relay.
Old Feb 5, 2003 | 10:20 AM
BLuDoHcReX's Avatar
Default Re: Car wont start. "AGAIN"!!!! (McD)
thats what i was thinking
Old Feb 5, 2003 | 05:32 PM
Camshaft's Avatar
Well PLEASE TEST DON'T GUESS
If the main relay is gone you will not have injector pulse or fuel psi, or spark.
So have someone check spark from a plug wire.
As well if the top end is spinning make sure T belt hasn't broken
later
cam
smokez187
Aug 10, 2007 11:35 AM
themex77
Feb 16, 2007 08:58 AM
sohc90rex
16
Dec 21, 2005 09:20 PM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
.ShawnD.
Aug 31, 2002 02:57 PM
