Anybody know where to find a TURBO KIT for a 96' H23 non-vtec prelude!
Does anybody know where i can find a turbo kit for a 96 h23 non-vtec prelude,if so what type of turbo.thanks.
http://www.dragturbokits.com
f-max.com
f-max.com
if you wanna hang with the hatches, your best bet is boost, because of the preludes weight you need to make more power than just bolt ons like a b16 or gsr, my car was running 15.5 w/ intake, w/ boost i havent run it yet but i pulled a car length on my buddies 91 hatch w/ ls-vtec running about 14.1 in the 1/4. that was only at 6.5 psi untuned. the boost is at 10-11 psi now and is wayyyyyyy faster than at 6.
had an f-max kit on my 92 lude h23.....
with 10psi , I ran 13.02 @ 108 mph.... (that with 18s on)
the best part was after I beat this mustang, he came to look at my car and said
WTF this thing is an automatic..... Hehehehehehehe (funiest stuff I ever heard)
goto f-max.com
if your considering the kit buy a fuelpump... (good luck) installing that pump though.....
goto f-max.com
Im actually selling some turbo parts for the h23a
Drag gen 2 Manifold $300 used for 2 months
Turbonetics t04e ball bearing turbo 50compressor trim, .48 t3 turbine housing $750 keep in mind this is BALL BEARING, i paid $1150 for it new. 2000 miles on turbo, no shaft play, in perfect condition. rated at 400whp.
Tial 35mm .45 bar wastegate $200 used for 2 months
Airtex inline fuel pump $70 used for 4 months
Missing Link Map sensor $50
Spearco Intercooler - Standard Drag size $250
If you buy the intercooler i acutally have one of the intercooler pipes you will need that come from the turbo that goes to the right side of the intercooler that i will sell you also.
I can also hook you up with the oil feed lines and fittings you will need for a very good price if you buy some things from me, all lines and fittings will be brand new and of top quality.
Everything is guaranteed to be in perfect working condition, add shipping to the above costs.
[Modified by GudeH23a, 10:47 PM 2/5/2003]
h-spec_crx
Feb 4, 2003 07:21 PM
, im running f-max, good kit, easy install, expect to blow ringlands!
