Front brakes making nose when stopping
Old Feb 4, 2003 | 04:06 PM
mickey513's Avatar
Default Front brakes making nose when stopping
My front brakes on my 94 Integra are making noise when stopping. Not the type of noise where the brake pads are low, but kind of like "blow air" noise. I checked the brakes and they still have plent of pad life left. Caliper and rotor looks ok.....
I have two ripped outer cv boots, one on both side, will this lead to the noise? Brakes fine, doesn't shake or anything when coming to a stop.
Old Feb 4, 2003 | 04:07 PM
EL Vap133's Avatar
Default Re: Front brakes making nose when stopping (mickey513)
Does it do it at all times or only when you brake? Any noises when you do turns?
Old Feb 4, 2003 | 04:31 PM
2k1_ITR_0736's Avatar
Default Re: Front brakes making nose when stopping (Vap133)
sounds like you need rotors to me. they might be warped. if they are fairly new, you can have them cut down and gett he warped away... NAPA does it.
Old Feb 4, 2003 | 04:50 PM
mickey513's Avatar
It only makes that noise when I am coming to a stop. Might be the rotors but it doesn't shake or anything when I stop plus I had the shop machine them when I had new brake pads installed about a year ago.
Old Feb 4, 2003 | 05:10 PM
EL Vap133's Avatar
Hmmm, are they cross-drilled rotors?
Old Feb 4, 2003 | 06:38 PM
mickey513's Avatar
nope, stock, whole car is stock.
Old Feb 4, 2003 | 08:08 PM
Rtzx9r's Avatar
GDD 1%
does it make the noise when you COAST to a stop? This will tell you brakes or boots.
Try changing the pads to a softer material and the noise should go away.
Old Feb 4, 2003 | 09:36 PM
94GsRacer's Avatar
Default Re: Front brakes making nose when stopping (Rtzx9r)
I had a problem before with the peice of metal that surrounds the bottom half of the rotor or whatever part of the rotor area.
But anyway, somehow the peice of metal bend onto my rotor and make annoying noises.. So make sure everything is secure under there.
Landshark68
Apr 20, 2007 10:01 AM
Hatchd
Aug 10, 2006 09:30 AM
GSRNetics
Jul 9, 2006 08:33 PM
96teggynonVtec
Apr 13, 2006 05:30 PM
dj626
Jul 10, 2005 05:31 PM
