Will a Honda 98-00 Accord Oxygen Sensor fit a 1994 honda civic ex coupe?
Old Feb 4, 2003 | 01:36 PM
kay_animation's Avatar
Default Will a Honda 98-00 Accord Oxygen Sensor fit a 1994 honda civic ex coupe?
Old Feb 4, 2003 | 02:18 PM
iam7head's Avatar
Default Re: Will a Honda 98-00 Accord Oxygen Sensor fit a 1994 honda civic ex coupe? (kay_animation)
1 or 2?
i dont think they will..
Old Feb 4, 2003 | 02:31 PM
jweller's Avatar
x-refrence the part numbers and see if they are the same.
i think the threads are the same. and if the they are both a 4 wire O2 sensor (which I KNOW the accord one is) the plug should fit. F23A1/F23A5 should show 0.6v or more with throttle fully opened from idle and engien warmed up. 0.4v or less with throttle fully closed quickly. Helms doesnt' have the info for the F23A4 as it is a different part that honda calls a A/F sensor. not sure how it's different. Oh yeah, this is for the PRIMARY O2 sensor on the 4 cyl accord.
HTH
OT: you a programmer? Saw your avatar. I do C/C++ in Unix myself
[Modified by jweller, 6:33 PM 2/4/2003]
Old Feb 4, 2003 | 03:02 PM
Default Re: Will a Honda 98-00 Accord Oxygen Sensor fit a 1994 honda civic ex coupe? (jweller)
Thanks alot. But yea, I'm a cs major so I do alot pr programming mainly using c++ and java. But thanks alot. I know my car is a 4 wire o2 sensor, so i'm hoping it will work.
Daniel Carter
Mar 21, 2019 07:53 AM
Suare
Oct 2, 2012 08:20 AM
timzer
Nov 28, 2011 04:19 AM
lrcoope4
Jul 22, 2011 11:11 PM
