Does anybody know HF's gear ratios?
Old Feb 4, 2003 | 11:45 AM
Hulkbuster's Avatar
Default Does anybody know HF's gear ratios?
I have a 90' HF and was fiddling around with the cartest program to find out my 1/4 and 1/8 mile times with the ZC I am about to order. And was gonna see how much slower it would be with the HF tranny as opposed to the Si tranny. Do any of you know the gear artios for the HF so I can put them into the program?
Old Feb 4, 2003 | 02:15 PM
SiRex91's Avatar
Default Re: Does anybody know HF's gear ratios? (Hulkbuster)
HF gears are really long and are designed for the sole purpose of gas mileage. Go with an Si tranny, I heard it makes a big difference over a HF tranny. I have the original drivetrain in my 91 CRX Si completely stock, it has 171k miles, burns oil, but it still hauls compared to newer sohc hondas.
Old Feb 4, 2003 | 04:02 PM
spettinger's Avatar
Default Re: Does anybody know HF's gear ratios? (SiRex91)
i do know of a friend of a friend around here--did his ZC swap several years ago, and kept the Hf trans with the intention of putting on a turbo in the future. when he ran it at the track, he had just shifted into third at the finish line. and it was NOT fast. at all.
the idiot decided to "fully build" his ZC for a turbo setup, it took has taken about 4 years to date because he had to order all this custom stuff because no one made anything for ZC's, the car sat so long that the rings rusted to the block. the guy is a dick to everyone, so everyone just thinks of him and laughs.
Old Feb 4, 2003 | 04:12 PM
Ef Whore's Avatar
Default Re: Does anybody know HF's gear ratios? (2ndhandCRX)
1st--slow. 2nd-slower. 3rd-slowest. 4th and 5th--complete and total ****.
Old Feb 4, 2003 | 04:19 PM
SIRX's Avatar
Default Re: Does anybody know HF's gear ratios? (Ef *****)
yeah there isn't anything stock on a HF that should be kept after a swap
Old Feb 4, 2003 | 04:45 PM
Just536's Avatar
Default Re: Does anybody know HF's gear ratios? (SIRX)
except the exhaust manifold (for your turbo).
Old Feb 4, 2003 | 04:57 PM
yellowcrx1991's Avatar
Default Re: Does anybody know HF's gear ratios? (Just536)
I got stuck with an HF tranny that came off a DX in a scrapyard for my SI , so I can give you first hand experience on what an HF tranny feels with an SI engine, its crap, top speed of 100mph(110mph downhill with a favorable wind and if you lean forward). Its not worth the time, effort, money or even your mere thoughts to use one. Unless your doing this for gas of course and even then I suggest you get a real HF Crx.
However in response to what EFWhore said above, 1st gear is not in the least bit crappy, its pretty much 1st and 2nd of an si tranny into one, but he's right about the rest, every gear after 1st sucks.
Old Feb 4, 2003 | 05:03 PM
SIRX's Avatar
dohh didn't think about that
Old Feb 4, 2003 | 05:06 PM
SIRX's Avatar
another thing with an HF tranny and a d16a6 you can hit the rev-limiter and 90 mph at the same time in second gear. you use 3rd as fifth and then it even sucks.
Old Feb 4, 2003 | 05:14 PM
eg6ajk's Avatar
here you go. supossedly there was another model with higher FD (3.88)
1速 3.250
2速 1.650
3速 1.033
4速 0.823
5速 0.694
R 3.15
FD 3.25
Old Feb 4, 2003 | 05:49 PM
civicwagonman's Avatar
Default Re: Does anybody know HF's gear ratios? (eg6ajk)
you can use the fifth gear in your si trans to lower your top rpms, but thats about all they're good for. the exhaust manifold and the wiring are good to keep.
eumoria
Nov 4, 2004 12:11 PM
jackzzz
16
May 20, 2004 10:01 AM
blah13
Oct 11, 2003 07:40 PM
MIRRAdekhtc
Jul 26, 2003 11:39 AM
paRRRker
Aug 7, 2002 07:40 AM
