Camber correction kit.
Old Feb 4, 2003 | 10:27 AM
wordzz's Avatar
Default Camber correction kit.
I've got my Eibach springs in for a while now and I've noticed that the inside thread of my tires is going bald. I asked around and found that I need to get a camber correction kit. Which one would be right for Eibach (Pro Kit) Lowering Springs 1.4 Inch Drop (FR) & 1.2 (RR)? My new tires are coming in a couple days and I'd like to get them in as soon as possible, but I'm not gonna ruin them by doin the same thing as to the old ones. Thanks.
Old Feb 4, 2003 | 10:53 AM
sgT's Avatar
sgT
Default Re: Camber correction kit. (wordzz)
you need an alignment
not a camber correction kit
Old Feb 4, 2003 | 11:15 AM
JonGP3's Avatar
no u are correct u will need a camber kit just any kit will do.. u won't be needing much adjustment since ur drop isn't much
Old Feb 4, 2003 | 11:49 AM
1bad-eg's Avatar
Default Re: Camber correction kit. (JonGP3)
You're right. Any time you lower a honda, you will always get more neg. camber, causing the inner part of the tire to wear more than the outer. That's why a camber kit is always a long term investment even if you lower your ride an 1-1 1/2.
Old Feb 4, 2003 | 12:28 PM
sgT's Avatar
sgT
Default Re: Camber correction kit. (1bad-eg)
you can have up to -2.5 deg of camber before tire wear becomes an issue
its just that none of you kids get an alignment done after you drop you car
so you THINK its the camber, when it is in fact the TOE that is killing your tires.
Old Feb 13, 2003 | 04:48 PM
SOHC_MShue's Avatar
Default Re: Camber correction kit. (sgT)
so i wouldn't need a camber kit for the sportlines on an ek coupe?
Old Feb 13, 2003 | 05:17 PM
slomofo's Avatar
GDD Member
Default Re: Camber correction kit. (SOHC_MShue)
If it's cambered in the back, just add washers to the two bolts that hold your upper control arms to the body. I think they're called upper control arms.
spray_bombed
13
Jul 2, 2007 11:48 AM
imonx850
Suspension & Brakes
Mar 14, 2005 08:47 AM
madcrossover
Oct 19, 2004 10:05 AM
IloveNewt
May 5, 2003 10:24 AM
lsvinny
Mar 14, 2003 05:50 PM
