need help about tranny and lsd oil.........
Old Feb 4, 2003 | 09:57 AM
meltSolid's Avatar
Default need help about tranny and lsd oil.........
ok lets say i hv a clutch type lsd, like kaaz, ats or watever....
is it ok if I just stick with the Redline MTL tranny oil?
another question is:
Redline is also making the gear oil for especially lsd/different unit, do I mix the tranny oil with the gear oil OR just applying the gear oil is fine?
THANX and help pls......
would really appreciate answers....
Old Feb 4, 2003 | 10:11 AM
meltSolid's Avatar
Default Re: need help about tranny and lsd oil......... (meltSolid)
ok to be more clear........
can i apply only the Redline 75W90 Gear Oil as tranny oil?
or Redline MTL is just fine or need to be mixed with MTL?
please help....
Old Feb 4, 2003 | 10:17 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i guess in theory you can. personally, until someone else has succes with running something other than manufacturers oil, i am not going to risk my lsd to try it. anyone else use it for, say a year, no problems?
Old Feb 4, 2003 | 10:19 AM
SlapSmak's Avatar
Default Re: need help about tranny and lsd oil......... (rodney)
alot of peeps run syn tranny oil, including myself. Redline here.
Old Feb 4, 2003 | 04:18 PM
meltSolid's Avatar
Default Re: need help about tranny and lsd oil......... (SlapSmak)
rodney: wat lsd oil u used b4?
are you saying i'm risking if i use the redline gear oil as tranny oil?
slapsmak: u hv the clutch type lsd as well? which redline you used?
thanx for inputs man.
rzz
Nov 17, 2010 01:52 AM
turbod92hatch
Feb 25, 2003 10:09 PM
bisleyjim
Jan 12, 2002 12:37 PM
ToneyTigre
Oct 13, 2001 10:52 PM
