HF manifold used as a b16 turbo manifold
The HF manifold is a D series, meaning it will only bolt to D series heads. The B16/B18 heads are bigger and the port spacing is much farther apart than on a D series. So no, it will not work.
My best advice to you would be to shop around. Most turbo manifolds are gonna run you around $400 for a decent one, but you may be able to find a deal. Check the forced induction forum, someone may be selling on there.
b20vtechb
Mar 3, 2005 12:07 AM
