LS swap into CRX 90-93 teg axles wont fit helppppp
i have ABS 90-93 axles and the hub where it goes in to the rotor wont fit. i know non ABS will fit, but can i just change the heads on the integra ones to the crx ones. will it work need help quick doing swap as we speak
I don't know why they won't fit.. Mine went on just fine and they were abs. I just removed the dust seal from the hub and the rubber seal from the axle.
Rob
Rob
i had that same problem with mine...after you remove that plastic ring you just have to move them around a little and they should fit...i used grease to get them in...
yeah its a 91 Si and the axles are 92 teg abs. i removed the ring on the hub but when i tighten that bolt that goes in the middle of the axles to secure the axles in, the wheels dont move do to the axles being so tight in there. when i compare the axles heads to each other the teg ones are different at the heads where it meets with a caliper. did you guys tighten yours all the way or just half way?
