*upgrade* Accord wagon rotor's BRAKE SETUP
Old Feb 4, 2003 | 05:11 AM
patastinky's Avatar
Default *upgrade* Accord wagon rotor's BRAKE SETUP
anyone know if they sell accord wagon brake up grade kits? i need to get one for my 92accord coupe.. i know it's possble to find all the pieces and assemble it myself. but i dont wanna scout i just wanna buy a complete kit.. if there even is one available... thanx in advace
Old Feb 4, 2003 | 05:16 AM
SearchBeforeUPost!'s Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (patastinky)
i think all you need is the calipers and brackets. you can get these through an auto parts store, usually with a core exchange. However, if you get them from a salvage yard it would probably be cheaper, and you won't have to give the old ones up. Then just get some new Brembo blanks and pads of your choice. http://www.nopionline.com has the discs for about $40 each.
Old Feb 4, 2003 | 05:34 AM
johnsaccord's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (Bda91acc)
All you need to buy is the rear trailing arm from a salvage yard. The wagon one's are nice, but since they are bigger, you may wanna upgrade the fronts to match.
Old Feb 4, 2003 | 06:37 AM
KTeller8's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (johnsaccord)
if the wagon is like the accord
order a pair of brembo rotors and get some bigger calipers
you can go with legend, or v6 or even oddessy if i am not mistaken
Old Feb 4, 2003 | 08:45 AM
Kazmans94cord's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (KTeller8)
yes the 1st gen oddessy.
Old Feb 4, 2003 | 12:16 PM
Brandon's Avatar
Life is Suffering
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (oO oatmeal Oo)
If you're really sadistic, you can use 2nd Gen Oddessy hubs and rotors to make it 5-lug rotor-over-hub.
Old Feb 4, 2003 | 02:08 PM
patastinky's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (F22Turbo)
thanx for the reply's, i was thinking of doing the 5lug swap i really wanted to get OEM type-S rims for my accord (TL type-S). but i just really wanted to get bigger brakes so i could have better braking power.. AEM big brakes is for 17inch rims' and up, i like my 5th gen accord rims so i am not going the AEM route agian thanx for the replys imma do more search into this .
Old Feb 4, 2003 | 09:49 PM
MrMike's Avatar
the wagon brakes is a simple upgrade. all you need is the rotors, calipers, and some shims. the caliper will bolt up to the nuckles with no problems. our accord coupe has the wangon front brakes. 15inch wheels will fit. the rotors are the same size as the ITR rotors and the calipers are the same part number. I'm actually trying to adapt these brakes on an EG hatch next with out having to get the very expensive ITR nuckles and hub.
[Modified by MrMike, 10:52 PM 2/4/2003]
Old Feb 5, 2003 | 06:57 PM
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (MrMike)
please explain the shims.
Old Feb 6, 2003 | 04:56 PM
patastinky's Avatar
yes please do !
Old Feb 6, 2003 | 07:52 PM
D21X's Avatar
daymn those rotors look badass with those rims.
Old Feb 6, 2003 | 09:36 PM
BuddyC's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (D21X)
i am doing this converson on my accord and plan on using the parts from a 97+ prelude. i am not completely sure on all the details on this as i am still researching it, but i will need the hubs, rotors, and calipers. i am concerned with the abs system, and the offset changing? if anyone has any comments please post.
Old Feb 6, 2003 | 10:38 PM
TypeSH's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (BuddyC)
are you going to use the control arms and suspension off a 97+ prelude onto an accord? what year accord? are you sure this will work?
Old Feb 7, 2003 | 04:22 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (TypeSH)
Check out http://www.TheAccordStore.com
They have a kit for $300 that gives you everything needed to do this swap. It comes with rotors, calipers, brackets, ect. from the Accord V6.
Old Feb 7, 2003 | 04:42 AM
urbanlegend21's Avatar
New User
that is all they are good for
Old Feb 7, 2003 | 06:34 AM
BuddyC's Avatar
i talked to a buddy online who did it with his 94 lx and says all he needed was hubs, rotors, and calipers. he used the rear trailing arm off an accord because he doesnt have existing discs in the rear.
i have a 94 ex so it should work fine. i dont think i need the control arms, cuz they will be positioned differently i believe. i am only concerned with offset, brake lines, and abs system. everyhting else seems to fit right for me, like i said im still doign research on it so i could be wrong.
Old Feb 7, 2003 | 06:46 AM
BuddyC's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (TouringAccord)
where did you see this? accord v6 in the 5th gen was still 4 lug. im not sure if the 6th gen parts will work.
Old Feb 7, 2003 | 08:42 AM
H-T Order of Merit
click above, then click on "4d 4cyl Sedan" or "2dr 4cyl Coupe" in the upper left corner. Then click on "brakes" from the selection at the top. Then click on "Performance" from the sub-departments. After that you will see a title that says "94-97 2/4dr 4cyl 11" FRONT BRAKE UPGRADE KIT". Here's a picture of what it looks like.
Hope this helps.
Edit: pic
[Modified by TouringAccord, 12:43 PM 2/7/2003]
Old Feb 7, 2003 | 10:29 AM
BuddyC's Avatar
oh i thought the upgrade was for a changeover from 4 to 5 lug. thanks anyhow
Old Feb 7, 2003 | 11:04 AM
H-T Order of Merit
oh, I thought someone was looking for the AV6 conversion not the 5 lug to 4 lug conversion. Well, for those who want to know where to get it, there you go. Sorry for the confusion.
Old Feb 7, 2003 | 01:34 PM
greensleeper's Avatar
if you needed shims then you have the wrong parts on your car. I've done this swap personally. Anyone with questions feel free to email me. Or search the site. I've read (and posted myself) a **** load of information on this swap and its possibilties.
Old Feb 7, 2003 | 01:50 PM
patastinky's Avatar
Default Re: *upgrade* Accord wagon rotor's BRAKE SETUP (greensleeper)
cool bout to go a search cuz i need to do this swizzy asap!
Old Feb 7, 2003 | 01:55 PM
patastinky's Avatar
green you have PM!
Old Feb 9, 2003 | 12:26 AM
patastinky's Avatar
green you have PM!
Old Feb 10, 2003 | 02:05 AM
mrnicolas's Avatar
got mine finished last friday, very nice improvement!
