Flywheel stock weights
Old Feb 4, 2003 | 04:40 AM
Tyson's Avatar
Default Flywheel stock weights
I'd like to know if the flywheel weights between CX, DX and EX and between EG and EK models are the same. I know they are interchangable at the least, but I'd like to know which is the lightest if they are different.
Old Feb 4, 2003 | 05:19 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Flywheel stock weights (Tyson)
all are 18-18.5 pounds, EXCEPT for the JDM D15B.
Old Feb 4, 2003 | 06:06 AM
eg6ajk's Avatar
Default Re: Flywheel stock weights (Mista Bone)
JDM D15B VTEC-E 15.8lbs ...
https://honda-tech.com/zerothread?id=371221
Old Feb 4, 2003 | 12:26 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Flywheel stock weights (eg6ajk)
the VX flywheel I had, was a standard weight unit at 18 lbs.
Old Feb 4, 2003 | 03:29 PM
Tyson's Avatar
hmmm others say the VX fw is definately lighter and obviously less massive by visual. do you happen to know if the VX still mates to an Si clutch properly at least?
SVOboy
May 14, 2006 01:09 PM
Tad
27
Sep 7, 2004 08:22 PM
spyderracing
Aug 12, 2004 07:16 PM
eg6ajk
Dec 29, 2002 02:58 PM
Lo-Buck EF
Jan 7, 2002 02:16 PM
