D-Series flywheels
Old Feb 4, 2003 | 04:03 AM
Tyson's Avatar
Default D-Series flywheels
Looking for a lighter stock flywheel, found this link searching, but it refers to JDM models. I know 92+ civic flywheels fit fine to a 90 CRX Si tranny (19lbs), but which specific US models (DX/CX/EX? EG/EK?) are lighter (17lbs)? or are they all the same weight and lighter than the Si original flywheel? Just want to make sure before I look for one. (yeah, did a search, find me a better link if you can)
Anyone know of someone with a lighter Civic flywheel for sale?
referred link: http://www.junauto.co.jp/products/dr..._honda.html?en
[Modified by Tyson, 5:05 AM 2/4/2003]
Old Feb 4, 2003 | 04:11 AM
CimorelliCRX's Avatar
Default Re: D-Series flywheels (Tyson)
i got a extra stock flywheel in my garage, i can take to a machine shop down the street and have them lighten it and sell it to ya for what they charge + shipping if you want.
Old Feb 4, 2003 | 04:18 AM
Tyson's Avatar
Default Re: D-Series flywheels (CimorelliCRX)
no, specifically not looking for a machined flywheel. i've got my reasons.
Old Feb 4, 2003 | 04:50 AM
crxfanatic's Avatar
New User
I have a 2g CRX HF flywheel and there is much less mass on the backside compared to my Si flywheel. I don't have weight differences, but it's got to be a couple of pounds lighter.
Old Feb 4, 2003 | 05:02 AM
Tyson's Avatar
Default Re: D-Series flywheels (crxfanatic)
good to know, but is it going to fit a Si clutch?
Old Feb 4, 2003 | 05:04 AM
crxfanatic's Avatar
New User
My clutchmasters clutch from my Si fit perfectly.
Old Feb 4, 2003 | 06:51 AM
Louie B.'s Avatar
I'm not sure about weights, but as far as what fits:
Any 90-00 D-series flywheel is going to fit with any 90-00 d-series clutch and pressure plate (212mm, 20 spline), the difference between the 90-91 and 92-00 clutch kits is the throw out bearing (cable vs hydraulic)
89 flywheels use a 200mm clutch, but still have 20 splines. If you have an 89, you can use the 90-91 212mm clutch kit if you get a 90-00 flywheel.
88 flywheels are the same as 89, (200mm) but the clutch is 21 spline instead of 20, I've been told (but have not confirmed this) that you can use a 90-00 flywheel and pressure plate if you get an 88 accord clutch disk.
Now to go through and weigh them all......
[Modified by thumpu77, 7:54 AM 2/4/2003]
Old Feb 4, 2003 | 07:14 AM
KevronsEG's Avatar
Default Re: D-Series flywheels (thumpu77)
i know that the 92-95 si flywhels i 18lbs and teh 92-95 cx flywheel si 13. so maybe its teh same for crx si and crx hf
Old Feb 4, 2003 | 09:03 AM
Urban Business
Guest
Posts: n/a
Default Re: D-Series flywheels (CIV616)
unorthodoz makes 8lb flywheels for 88-91
Old Feb 4, 2003 | 03:28 PM
Tyson's Avatar
Default Re: D-Series flywheels (limoZeen)
just interested in stock weights dudes...
Old Feb 4, 2003 | 07:00 PM
PaImportTuner's Avatar
to confirm this.. well this is my current setup and i chirp 3rd. on all O.E. parts
also on another note the y8 is prolly the heaviest of the D series the lightest flywheels were from 88-91 our flyhweels..
Old Feb 4, 2003 | 07:21 PM
Louie B.'s Avatar
Default Re: D-Series flywheels (PaImportTuner)
to confirm this..
thanks.
Hey Tyson, is that Congar ol'Ondar on your avatar? sorry, had to ask.
court76wi
Nov 26, 2007 05:10 PM
rice is nice
13
Apr 27, 2005 02:15 PM
Renegade
11
Mar 21, 2004 09:42 PM
clsmooth
Sep 8, 2003 06:03 AM
clsmooth
Sep 7, 2003 11:20 AM
