72,000 miles: Should I get timing belt & water pump replaced?
Old Feb 3, 2003 | 09:05 PM
Cspeclude's Avatar
Default 72,000 miles: Should I get timing belt & water pump replaced?
Actually, I am soon getting an ACT clutch and Fidanza flywheel too. So the real question is while those two items are being installed, should I get the timing belt and water pump replaced at the same time to save time, money and a piece of mind that everything will be working fine? Also just tonight, about 1/4 of the power steering belt tore off. I am soon going to replace it in a couple of days when I have the time, but should I just leave it for now or take it off? Steering does feel fine as of now. Please help.
Old Feb 3, 2003 | 09:33 PM
str8rcn's Avatar
Default Re: 72,000 miles: Should I get timing belt & water pump replaced? (Cspeclude)
Replace the timing belt and water pump before 85000-90000 for sure.as far as the power steering it should be fine just make sure that its not ripping cause you dont want it to shred off and get caught in the alt belt and throw it off.
[Modified by str8rcn, 10:34 PM 2/3/2003]
Old Feb 3, 2003 | 09:45 PM
fastludeh22's Avatar
Default Re: 72,000 miles: Should I get timing belt & water pump replaced? (str8rcn)
when you change the t-belt and water pump, id change the oil pump and balancer belt also. also while you in there you should put on a set of adjustable cam gears.
and just watch the ps belt like the other guy said
Old Feb 4, 2003 | 04:42 AM
Cspeclude's Avatar
Default Re: 72,000 miles: Should I get timing belt & water pump replaced? (fastludeh22)
Thanks for the advice
Old Feb 4, 2003 | 07:42 AM
Daemione's Avatar
Just as an FYI, I don't believe doing the whole timing/balancer belt, water/oil pump deal at the same time as the clutch/flywheel will save you any money. They're at opposite sides of the engine, and won't save you on any labor by doing them simultaneously.
So unless you really pound your car hard (track time), you should be able to wait 10-15k miles before doing the timing belt fiasco. Maintenance schedule lists it at 90k miles for severe conditions, 105k for typical.
And like the others have said, keep a very close eye on that accessory belt, & change it as soon as you get a chance.
Old Feb 4, 2003 | 07:44 AM
tec-9-7's Avatar
Default Re: 72,000 miles: Should I get timing belt & water pump replaced? (Daemione)
What he said.
Paul
Old Feb 4, 2003 | 03:05 PM
mickey513's Avatar
I didn't replace the timing belt and water pump on my 94gsr until 108k, even then the mechanic said I could squeeze out another 10k-12k miles.
bhath19
Aug 2, 2004 08:05 PM
Miz101
Feb 15, 2004 07:07 PM
1998hondaaccord
Sep 18, 2003 07:25 AM
garados
Oct 26, 2002 09:34 PM
Neeko
May 4, 2002 12:41 AM
