what door do i have?
i did a search and to my understanding the crx doors differ in that:
88-89 have frame mounted belts
90-91 have door mounted belts
i have an 89 si with door mounts belts? is that possible?
You have pillar mounted or frame as you call them. I mean **** how hard is it to look if they are on the door or not on the door. If not maybe CRX was different, but I know for Hatch that is true.
[Modified by FourthGenHatch, 3:16 AM 2/4/2003]
For the CRX, ALL 88's had the pillar mount belts. In 89, the HF had pillar belts while all others went to door belts. 90-91 are all door belts. This is only for USDM
I guess it depends on when your car was built.....I have an HF with a build date of 4/89..I have frame mounts and I have also come across Si's with the same build time frame with both ( frame and door)...I guess it all depends on where in the production run your car was at when the changeover was made.
B2FiNiTY
20
Dec 13, 2003 09:46 AM
