How do you take out cluster in 94 accord ??
i need to take out my cluster in my 94 accord to replace bulbs ?? anyone know where to start ??
can someone write all the steps ?? where all the screws are ?
THanks - let me know
[Modified by muzikant25, 2:10 AM 2/4/2003]
You will need to pull the center console because underneath where the temp **** and fan **** are 2 non-visible screws that will need to be removed. Next pull out the defrost switch - remove the screw that is visible. Next pull out the cruise/dim switches - remove the visible screw. Where the guage cluster is are 2 screws along the top of it along the curved part. You should be able to gently pry and pull the whole dash assembly out. Once this is done - it is pretty straight forward as you will see the screws that will need to be removed next. Once that is done, disconnect the wire harnesses plugged in the back of the guage cluster and voila - guage cluster in your hand!
[Modified by Hondaaccordvtec, 9:44 PM 2/3/2003]
[Modified by Hondaaccordvtec, 9:45 PM 2/3/2003]
http://www.accordcompany.com/howto.php
They have an article on removing the cluster to install new guage faces.
Hope this helps.
Hope this helps.
tvn_1010
Oct 4, 2002 10:44 AM
