OBD0-OBD1 ecu conversions
Old Feb 3, 2003 | 02:42 PM
Bseries's Avatar
Default OBD0-OBD1 ecu conversions
call this guy named Vernon @559-733-4711. he can convert OBD1 ECU's to OBD0 plugs. I hear it is clean and works well. no need for jumper harnesses.
Old Feb 3, 2003 | 04:15 PM
4drEF's Avatar
Keyboard Humorist
Default Re: OBD0-OBD1 ecu conversions (Bseries)
So do you have to repin your underdash harness then?
Old Feb 3, 2003 | 04:28 PM
xsolidcellx's Avatar
Default Re: OBD0-OBD1 ecu conversions (4drEF)
sounds like he's gonna chop off the end off the obd1 ecu and put the obd0 ones on the obd1. If so is a cheap way to go. Downside is if anything happen to your ecu you cant just pop in another one. (no ecu sharing with ypur buddies) upside is that it can be done for insanely cheap.
Old Feb 3, 2003 | 05:22 PM
4drEF's Avatar
Keyboard Humorist
Default Re: OBD0-OBD1 ecu conversions (xsolidcellx)
Sounds to me that he desolders the plugs in the OBD-1 ECU and then replaces them with the plugs from OBD-0. That would look great, but wouldn't that require you to rewire your underdash harness so all the wires go to the right places? Then you could not go back to OBD-0 unless you redid all the wiring again.
Old Feb 3, 2003 | 06:00 PM
I Gotta Question's Avatar
You can always convert to obd1 it's only like 20 wires I did it for my Z6. IM me if your interested I'll tell you for nothin.
V-tec_91_Hatch
Dec 3, 2012 12:18 PM
chrysanderson
Nov 4, 2010 12:38 PM
meallout
Jan 25, 2009 12:21 PM
I AM WEASEL
Dec 21, 2007 08:10 PM
