owned myself while doing s2k antenna conversion
Old Feb 3, 2003 | 08:26 AM
98type_r's Avatar
New User
Default owned myself while doing s2k antenna conversion
slipped while removing the oem unit, damn screwdrive scratched up my paint
a closer look
Old Feb 3, 2003 | 08:28 AM
RTW DC2R's Avatar
Default Re: owned myself while doing s2k antenna conversion (tie par)
DOH!
machgo5go's Avatar
time for G27 scratch remover!
Old Feb 3, 2003 | 08:30 AM
RTW DC2R's Avatar
Default Re: owned myself while doing s2k antenna conversion (machgo5go)
that crap doesnt work.
Old Feb 3, 2003 | 08:34 AM
yoshi234's Avatar
I shoot brides
00psr0z!
Old Feb 3, 2003 | 08:36 AM
B16A2-EM1's Avatar
Default Re: owned myself while doing s2k antenna conversion (yoshi234)
I like that Idea, Propz
Eva01's Avatar
OWIE!! Time for some touch up paint.
Old Feb 3, 2003 | 08:37 AM
Larkin W.'s Avatar
Touchup paint OWNZ that scratch!
Larkin, who's ITR is owned in many places by touchup paint.
Old Feb 3, 2003 | 08:39 AM
Junior_r's Avatar
Touch-Up Paint
08703-NH0AA
$3.25
Old Feb 3, 2003 | 08:47 AM
ITR 00-1567's Avatar
New User
How snug is the antenna? I installed mine, and it is a little loose. I have tightened it, but I am still able to move the base a little. I also had to put the silver ring back in between the antenna and base. It sits better now, but still not very tight.
Thanks,
Ian
Old Feb 3, 2003 | 08:53 AM
sackdz's Avatar
Default Re: owned myself while doing s2k antenna conversion (ITR 00-1567)
Haha I did the same thing
Old Feb 3, 2003 | 08:54 AM
ej1civic's Avatar
Old Feb 3, 2003 | 08:56 AM
Mugen Mike's Avatar
That suck Little touch up paint should cover it fairly well.
Antenna looks good too
Old Feb 3, 2003 | 09:15 AM
Asahi's Avatar
Thanks,
Ian
There is a thread that explains how to make it snug. You have to continue to lower the threaded piece the antenna goes into until it is snug. This will not ever be snug enough to resist the strength of your hand it you try to MAKE it move. But will be strong enough to keep water out.
Old Feb 3, 2003 | 09:30 AM
Alexander's Avatar
Default Re: owned myself while doing s2k antenna conversion (MugenMike)
That antenna was great until I realized I got close to no reception
sure looks sexy though
I have one with the "kit" lying around in the garage, anyone want it?
//Alex
Old Feb 3, 2003 | 09:34 AM
Asahi's Avatar
Default Re: owned myself while doing s2k antenna conversion (AVD23)
//Alex
Alex, just add home stereo wire to the under side of the wantenna kit. Mine picks up just fine.
Old Feb 3, 2003 | 09:37 AM
Nimbus's Avatar
Put a VTEC sticker over the scratch.
Old Feb 3, 2003 | 09:38 AM
TypeR 01 886's Avatar
Default Re: owned myself while doing s2k antenna conversion (Asahi)
Yes the antenna looks good (Better reception?) also the touch up paint should work like a charm with something like that. Scratches are always better than dents (at least ones as small as you made) both suck though
Old Feb 3, 2003 | 10:06 AM
98type_r's Avatar
New User
Default Re: owned myself while doing s2k antenna conversion (TypeR 01 886)
reception is worse, equivalent to then the oem mast is stuck down (part of the reason i did swap).
its kinda loose now, i'll get back to tighten it this weekend, and i'm buying a whole pile of copper wire to help boost the reception.
Old Feb 3, 2003 | 10:42 AM
DarthLuder's Avatar
New User
You should have did it patiently. I took my time and nothing happened. My antenna placement is a little angled and goes with the stock wing.
Old Feb 3, 2003 | 10:43 AM
DarthLuder's Avatar
New User
In the city is no problem, but when i drove to Iowa reception sucked. No biggie just play a cd.
Old Feb 3, 2003 | 10:50 AM
Hooch'n's Avatar
Default Re: owned myself while doing s2k antenna conversion (ITR GURU)
GS27 has worked on my ITR, maybe people arn't using it correctly! I've used it on my ITR, Hatchcrap and my old car.
Old Feb 3, 2003 | 11:16 AM
Nameless RB26's Avatar
Default Re: owned myself while doing s2k antenna conversion (RTW DC2)
Yes it does.. it depends on what you're using it on. It's not magic that's for sure..
I'd give it a try on that scratch.. it might help..
Old Feb 3, 2003 | 11:28 AM
TheHater
Guest
Posts: n/a
It dosent it acutally made my scratch worst
Old Feb 3, 2003 | 11:29 AM
B2FiNiTY's Avatar
Ouch. Touch up paint time.
