So what can I do with an HF motor to make it faster???
Old Feb 3, 2003 | 07:35 AM
CRX A4's Avatar
Default So what can I do with an HF motor to make it faster???
Just curious,
Currently I am putting together a swap for my '91 CRX HF, but in the meantime, what can I do to the stock motor to make it atleast a little faster, I am hoping to break the 60 MPH mark, heh,
I don't mind spending a little money, i just want to make this thing as fast as an HF can be until i do the swap
So far i have put a couple little things on the motor, such as CAI and exhaust, I coudln't possible see how the motor breathed through a tube that could be clogged with a ping pong ball
Someone mentioned that i could put a D16Z6 head on the motor, but I read that it would not work
Any help would be great
Old Feb 3, 2003 | 07:38 AM
kyle h.'s Avatar
Default Re: So what can I do with an HF motor to make it faster??? (CRX A4)
https://honda-tech.com/zerothread?id=400958
Old Feb 3, 2003 | 07:41 AM
rioninja's Avatar
D16z head is doable, but compression would be pretty high.
Plus, for the price of the head/headgastket/headbolts/timing belt/etc, i would just save for the swap.
If it was my car, i would get an intake manifold, throttle body, and exhaust manifold from an SI, if you can find one in the u-pull-it yard.
Thats about all i would want to invest. Your other option is to just deal with the lack of power until you can afford to swap.
Old Feb 3, 2003 | 07:47 AM
Hondasaurs's Avatar
Default Re: So what can I do with an HF motor to make it faster??? (Rioninja)
You can't swap a head on the HF unless you change the pistons. The HF is an 8 valve engine, meaning the pistons only have valve reliefs for the 8 valves.
Old Feb 3, 2003 | 08:09 AM
kyle h.'s Avatar
Default Re: So what can I do with an HF motor to make it faster??? (ZC_CRX)
didn't we already discuss this and find that it is doable?
Old Feb 3, 2003 | 08:56 AM
Trinity's Avatar
https://honda-tech.com/zerosearch click me click me
Old Feb 3, 2003 | 08:57 AM
Hondasaurs's Avatar
Default Re: So what can I do with an HF motor to make it faster??? (kyle h.)
It's doable if you chance the pistons. Otherwise the valves will collide into the pistons if you use the HF internals.
1990hondacrxhf
19
Apr 11, 2007 08:12 PM
civic_std
Feb 12, 2006 06:38 PM
No
Nov 15, 2005 08:40 AM
laterdaz
Mar 7, 2005 07:02 PM
JayhawkFAn
10
Sep 7, 2004 10:36 AM
