Nitrous in my b18a
Ive got a stock b18a with 160k on the odometer. Compression test read 175psi- 200 psi. Will it be able to take a 65 shot?
BTW, since im a trial user and can't PM can someone PM "JDM IS RICE" and tell him to email me at dan8520@hotmail.com cuz i want his zex kit.
Thanks a lot.
[Modified by humpy012, 4:18 PM 2/3/2003]
Thanks a lot.
prolly not... a wide gap like that means your rings are not looking good...
any variance larger than 20 between cylinders is not good for fi or juice..
but... like everyone these days... slap it on there... run it till she blows and rebuild.
you always run the risk .. but if you must ... id make sure your fuel is tuned perfect .. if its pretty much a stock motor .. then just reset your ECU properly and let it recalibrate itself/fuel... is it the original o2 sensor ? with 160k on it ? could always slap a new OEM spec o2 sensor in ... then recalibrate .. colder spark plugs like a 7 and a NX 50 wet shot
prob wouldnt venture past that, ever, on your present setup
