Road noise (99 coupe)
I am experiencing some really loud road noise in my 99 accord ex v6 coupe. It's lowered with H&R stage 2 springs and has Dayton Daytona tires on the stock wheels. My front tires are basically bald, and my rears are almost full tread. The sound is like a really loud humming that changes pitch depending on how fast I go. It usually becomes audible around 35-40mph, and gets damn annoying at about 60.
Is the road noise from the tires or from something I should be more concerned about.
Basically I think what he is saying is that your tires are "Cupped" in other words there is a space on your tires that is no longer making contact with the road. So as you speed, it makes noise .. if that makes sense.
Right... and this happens when you lower you car more than an inch and don't get an alignment done and drive on it for a while.
An alignment consists of camber and toe adjustments. If your toe is off... your tires will drag.. and cause them to be clamshelled... which in time will cause some SERIOUS tire hum.
If your problem turns out to NOT be the wheel bearing... get new tires and an alignment done (camber/toe) and you'll be good to go.
Oh yeah I forgot I can edit my own title! Yay!
You might want to check the brakes. If they're too worn out, you'll hear this loud screeching noise whenever you're driving that doesn't stop till you change pads.
I've had the brakes replaced twice. That's fine. I've had an alignment after I lowered, so I'm pretty sure that's fine. It's a humming noise that changes pitch depending on my speed.
If it doesn't change pitch or tone in a curve, like an exit ramp, then it's most likely not a wheel bearing
if it is at all related to tire noise, it will be different on different surfaces. like between asphault and concrete
ive got the same noise in my 00. it goes away when i take a hard left (kinda), and the faster i go the louder it gets. so it is probably the right-rear wheel main bearing, right?
probably left front, but they play tricks on you. I swore my left front one was bad but it turned out to be the right front.
I got REALLY lould eventually. you can drive on it for a little while before it gets too bad.
r_u_live
Oct 24, 2014 11:53 AM
angrysmileyface
11
Nov 20, 2011 04:55 PM
