cold air bypass valve..does it really worK?
Old Feb 3, 2003 | 12:44 AM
Powered by Rowena Galam's Avatar
Default cold air bypass valve..does it really worK?
i'm thinking about buying an intake for my gsr in my eg..i wanna go w/ the cold air but i dont know anyone that's actually used the bypass valve so i dont really know if it works..so..any of u that's used it..does it work/
Old Feb 3, 2003 | 01:13 AM
EK MONEY's Avatar
Default Re: cold air bypass valve..does it really worK? (Powered by Rowena Galam)
it works, and according to your located,, your gonna need it...... Dont forget the meet!
Old Feb 3, 2003 | 01:16 AM
BlackDeuceCoupe's Avatar
HT White Ops
...i dont know anyone that's actually used the bypass valve so i dont really know if it works...
They only work if your intake is completely submerged. So, if you drive your car around in bumper-high pools of water, get one. Otherwise, they are useless. They do NOT magically seperate water from air, if that was what your were thinking...
Old Feb 3, 2003 | 06:34 AM
cash459's Avatar
Default Re: cold air bypass valve..does it really worK? (BlackDeuceCoupe)
Well, according to where you are located, you are more than likely going to need it as some point in time.....and even if you arent driving around in pools of water, why risk it!? its better to be safe than sorry, unless of course you have money to throw around on a new engine.....
Old Feb 3, 2003 | 10:46 AM
Default Re: cold air bypass valve..does it really worK? (cash459)
which cold air intake would u guys recommend? r there any that offer some kind of warranty on their bypass valves?
Old Feb 3, 2003 | 12:17 PM
tnbigdawg's Avatar
didn't they recall these? I could have sworn they have.
Old Feb 3, 2003 | 12:32 PM
HatchSteer's Avatar
Default Re: cold air bypass valve..does it really worK? (tnbigdawg)
they don't work. The bypass valve basically defeats the purpose of having a CAI. Don't bother. Go short ram if you don't have the guts to use a CAI. Honestly, the bypass valve is worthless.
Old Feb 3, 2003 | 12:57 PM
BeerBaron105's Avatar
Default Re: cold air bypass valve..does it really worK? (BitterCivic)
i dont understand how a byp *** valve works, when ur filter is completey submerged, then the engine sucks air through the by pass valve instaed? so that it has an alternative route of receiving air, rather then sucking up the water
am i right?
Old Feb 3, 2003 | 01:17 PM
BackSideSA's Avatar
Default Re: cold air bypass valve..does it really worK? (BeerBaron105)
am i right?
correct...
go with the new AEM V2, be hearin alot of cool **** about these things. i used to carry a flat head with me so when it started to rain i would pull up to a gas station and take off the cold air part and reattach the filter in the engine compartment
get a little wet save your motor and 50 bucks
[Modified by HybridHackBatch, 10:18 PM 2/3/2003]
Old Feb 3, 2003 | 01:32 PM
nerdsports's Avatar
Default Re: cold air bypass valve..does it really worK? (HybridHackBatch)
my friend had an aem cai with a bypass valve. he said he felt a decrease in power with it... but i would think it works. i saw a test on super street or sport compact car .... they had the ***** to try it on an nsx!!!
Old Feb 3, 2003 | 01:35 PM
t0p_sh0tta's Avatar
Default Re: cold air bypass valve..does it really worK? (nerdsports)
Only because it was completly submerged in water. It takes a certain ampount of negative? pressure in order for the rubber one way valve on the bypass to open.
Old Feb 3, 2003 | 03:06 PM
SRT-WHORE's Avatar
This topic is ancient. Try search and that will help you. I remember this topic from a long time ago.
Old Feb 3, 2003 | 03:11 PM
SOHC_MShue's Avatar
Default Re: cold air bypass valve..does it really worK? (SILINITY16)
i'll sell you a brand new one i never got around to putting on
Old Feb 3, 2003 | 04:57 PM
HT White Ops
they don't work... Honestly, the bypass valve is worthless.
Yes, they were coming apart, getting sucked into the TB opening, locking the butterfly WFO.
Old Feb 3, 2003 | 04:58 PM
HT White Ops
they don't work... The bypass valve basically defeats the purpose of having a CAI.
True! It's like sticking a stopsign in the middle of a freeway...
Old Feb 3, 2003 | 05:02 PM
HT White Ops
i dont understand how a byp *** valve works, when ur filter is <FONT COLOR="red">completey submerged</FONT>, then the engine sucks air through the by pass valve instaed?... am i right?
You are 100% correct! Then, when the filter is un-submerged, the bypass valve closes and you end up sucking water into your engine anyway; the water that is 'standing' inside the intake tube.
Old Feb 3, 2003 | 06:45 PM
HT White Ops
Hopefully, by now, everyone is getting THE point, but just in case...
SOURCE: http://www.aempower.com/induction.htm
<u>Air Bypass Valve</u>
AEM’s patented air bypass valve virtually eliminates the chance of hydro-lock <FONT COLOR="red">in the unlikely event</FONT> the filter of your AEM Cold Air induction system becomes <FONT COLOR="red">submerged</FONT> in water. The valve installs along the upper portion of the inlet pipe and shuts down induction at the filter when it becomes <FONT COLOR="red">submerged</FONT>, rerouting air through its external diaphragm to keep water out and air flowing in.The AEM Air bypass valve is for use only on AEM Cold Air induction systems, and is not for use on forced induction vehicles. <FONT COLOR="red">Pending C.A.R.B. exemption</FONT>. Patent # 6,394,128.
Old Feb 3, 2003 | 07:02 PM
.Ryan's Avatar
Don't Trust Anyone
ROTFLMAO.
Old Feb 4, 2003 | 02:52 AM
HT White Ops
Default Re: cold air bypass valve..does it really worK? (SpoonSportsEH2)
ROTFLMAO
No, ****... Here's a pic from the fabled AEM bypass/NSX test. This guy just pulled the air filter out of the fish tank (filter had to be SUBMERGED for the valve to open as noted above).
What do you think he is watching get sucked up the tube? Hint: it ain't air!
Old Feb 4, 2003 | 10:32 AM
haha..that guy looks like the guy from that 70s show
anyways..thanx for all the feedback..for the most part i guess i'm gettin the impression that it does work but it's still a risk..b/c where i live..i have been submerged in at least 2 ft of water at one point and my stock motor blew b/c of no bypass valve
has anyone or has anyone heard a RELIABLE story where someone had a bypass valve and the motor still went when submerged in water?
Old Feb 4, 2003 | 10:33 AM
Built to Spill's Avatar
el diablo
that v2 intake looks retarted i would never put somethin that fugly on my car.
________
New mexico medical marijuana
Old Feb 4, 2003 | 11:06 AM
TheHeyta
Guest
Posts: n/a
Comptech Ice box ...no need for a BP Valve
Old Feb 4, 2003 | 04:01 PM
neof69's Avatar
I have seen the by-pass valve on an AEM lose 7hp on a dynojet..
Old Feb 4, 2003 | 04:10 PM
Default Re: cold air bypass valve..does it really worK? (SportInjected)
sorry if this is a noob question but..why's that?
Old Feb 4, 2003 | 07:50 PM
sparq's Avatar
Try searching the web on products someone mentions that you dont know about - youll learn more then someone telling you.
