4 door gsr exhaust
Old Feb 2, 2003 | 08:53 PM
Clean91B18A1's Avatar
Default 4 door gsr exhaust
Will the GSR 4 door exhaust fit on my 4 door LS? If not what needs to be modified?
Also the exhaust is axle back. Is it better to buy axle back or cat back?
[Modified by 4DrSlushBoxTeg, 6:21 AM 2/3/2003]
Old Feb 3, 2003 | 02:29 AM
slomob18b's Avatar
Default Re: 4 door gsr exhaust (4DrSlushBoxTeg)
Depends on what year the exhaust is for.
94-01 LS and 00-01 GSR cat-back exhausts are interchangeable.
94-99 GSR have different length cats making them not interchangeable with 94-01 LS
All 94-01 4dr Axle-back exhausts are interchangeable. The 2doors fit too, but the tip would not reach the end of the rear bumper.l
An aftermarket cat-back exhaust should should be better because of the bigger piping.
Stock GSR exhaust on an LS is pretty much useless in terms of performance.
Old Feb 3, 2003 | 02:55 AM
I wasn't talking about the oem one I was referring to after market ones like Thermal, Greddy, such like that.
Old Feb 3, 2003 | 03:23 AM
slomob18b's Avatar
same applies for the aftermarket ones. if a company only makes them for 4door gsr then you can bring it to a muffler shopand have them cut or extend some of the piping. should be easy for them
Old Feb 3, 2003 | 03:33 AM
Default Re: 4 door gsr exhaust (slomob18b)
was trying to avoid that route (take it to a shop) and do everything myself as in bolt in and go play. Also what if I added an aftermarket cat? Will that help any in the different cat lengths?
Old Feb 3, 2003 | 04:14 AM
slomob18b's Avatar
94-01 LS and 00-01 GSR have the same length cats
94-99 GSR i believe have shorter cats than the LS
b20quang
Jun 9, 2009 07:15 AM
musTerdh22eg
Dec 28, 2008 08:19 AM
Liquidgsr
Jan 15, 2004 08:29 AM
MachAF
Nov 9, 2001 12:32 PM
