grinds when shifting only if wheel is locked
Old Feb 2, 2003 | 08:16 PM
94thundergrey's Avatar
Default grinds when shifting only if wheel is locked
wonder if anyone experience the same or if it is normal.
I had a 95 gsr, at the time it had only 25k on the car, during winters, whenever i am stopping or slowing down at an intersection, and the abs is active and I try to put the car in first or second gear, it always grinds. if the abs is not active, it will not grind. I thought the hydrolic pump is not capable to supply the abs unit and the clutch. (maybe they have deperate pumps)
now I have a 94 rs, whenever I am slowing down and the wheels locked up from slippery surface(no abs) and I try to put the car in gear, i will grind. why? it will not grind if the wheels are not locked up.
never drive fast enough to turn in 3rd gear and have wheels lock up. so don't know about other gears.
anyone experienced this or have some thoughts?
Old Feb 2, 2003 | 08:31 PM
fivespeedintegra's Avatar
Default Re: grinds when shifting only if wheel is locked (94thundergrey)
https://honda-tech.com/zerothread?id=400589
Old Feb 2, 2003 | 08:40 PM
Default Re: grinds when shifting only if wheel is locked (fivespeedintegra)
I should of searched.
I thought I surf enough to read most post, but the forum moves fast.
still no one knows why.
PolyPill
Sep 14, 2009 05:39 AM
thecrackerjack
Feb 15, 2008 11:54 AM
fcuked
23
Jan 18, 2004 08:42 PM
wall of tvs
Jan 29, 2003 10:51 PM
