MPFI wire confusion...arrggg
Old Feb 2, 2003 | 08:09 PM
01IntegraSE's Avatar
Default MPFI wire confusion...arrggg
ok, so everything is diconected (wire wise) i wrote down the wire colours and can someone tell me what they are for and were i put them on the manafold?
I got the TPS all connected right.
now on the manafold i have two wires commin out of the back with the wire colours Blue and one yellow/black....were do i connect them?
i have the one i extended that was green/yellow and red/yellow.. were does this connect?
also got a orange wire and yellow/black wire connected to nothing
and ifi rememberfrom the engine harness i got blue/yellow and yellow/black ...
anyone help? once this is figured out all i need is TB and i am set to go! i hate seeing my car parked not running
if i had a camera i';d take pictures
Old Feb 2, 2003 | 08:26 PM
chad174's Avatar
Default Re: MPFI wire confusion...arrggg (90CivicDx)
Ok, I don't know all of those wires, but maybe after i tell you some you can solve it by process of elimination. The Green/yellow and red/yellow wires should go to the EACV, which is the sensor on one of the runners of the intake manifold. Thge orange and yellow/black wires should go to that sensor on the bottom side of the intake manifold. I don't know about the other ones. I'll try to take a look at my car in a while and see if i can name the other ones. Good luck.
Old Feb 3, 2003 | 12:20 AM
evilxkid's Avatar
Default Re: MPFI wire confusion...arrggg (chad174)
here's a cool diagram i made when i did my conversion, don't know if it will help but it's the best i can do for ya.
good luck.
Old Feb 3, 2003 | 06:10 AM
thanks if you could lok at be cool! i wish i knew someone around here with a si i couild just look at theres
prelude182
Feb 24, 2011 11:23 AM
90_EX_Civic
Mar 21, 2009 07:59 PM
raidacaipo
May 12, 2008 08:07 PM
Black R
Sep 28, 2005 06:16 PM
Racermech
May 23, 2005 08:29 AM
