People who changed their clutch master and slave cylinders. I need your help
Old Feb 2, 2003 | 03:12 PM
AndyD's Avatar
Default People who changed their clutch master and slave cylinders. I need your help
Hey guys, I tried to change my clutch master and slave cylinder today. Everything was going as planned until I tried to take out the nut holding the master cylinder in. The bolt that holds the master cylinder tight near the clutch pedal.
How do I take this bolt out. The one that is in the upper left hand corner?? I could get a socket in that tight space. Any ideas?? Tricks??
Also, what is the best way to bleed the system?? At the slave cylinder??
Thanks
Old Feb 2, 2003 | 08:26 PM
rokestah's Avatar
Default Re: People who changed their clutch master and slave cylinders. I need your help (AndyD)
Luckly, I have extended warranty so I didn't have to do it myself in this subzero weather. But maybe this post may help somewhat. If not, you can always try PMing this guy.
http://www.superhonda.com/forum/show...aster+cylinder
By the way, didn't you say you had problem with your cltuch last October...?
Old Feb 2, 2003 | 08:44 PM
AndyD's Avatar
Default Re: People who changed their clutch master and slave cylinders. I need your help (rokestah)
LOL. Actually, those are the exact instructions I used to do the install.
And YES, I did post about this back then. LOL That's funny you remembered. I FINALLY got around to installing it today. The weather hasn't been that great to do it myself.
Thaks for the help.
Old Feb 3, 2003 | 04:06 AM
prelude1897's Avatar
I never did take the bolt off the clutch pedal, I just left it on there and used it whenever I installed the new master cyclinder....
Old Feb 3, 2003 | 09:47 AM
laughinxxx's Avatar
New User
Default Re: People who changed their clutch master and slave cylinders. I need your help (prelude1897)
You'll bleed the fluid out of the slave cylinder that is bolted to the front of the block.
Ajr
Honda S2000
Sep 21, 2014 11:24 AM
hawtsoss
Oct 21, 2008 03:39 PM
ianae86
Mar 16, 2006 01:59 AM
