Handling: 2003 Civic SI vs 2003 RSX-S
I don't mean to turn this post into a which car is better flame war.
I am very curious, which car would handle better? Both cars would be 100% stock, and I assume they will have equal drivers.
Does the Civic SI have a softer suspension than the RSX-S like the base RSX?
Thanks in advance.
Thanks in advance.
...which car would handle better? Both cars would be 100% stock, and I assume they will have equal drivers...
stock the RSX-S has stiffer or whatever you want to call it handling. There is a warning in the manual about bottoming out on certain hills for the Type S (not like its that low anyway).
Who keeps stock suspension anyway. Im sure they'll both handle good with a nice pair of coilovers/springs.
Ive driven both, and the RSX is superior. Stiffer chassis and less body roll, although the stock tires on both are pretty crappy.
The chassis is the same between the two cars. The RSX-S has slightly firmer suspension and a larger rear anti-sway bar.
Tires are actually a bit better on the RSX-S, accounting for better skidpad and slalom numbers. This makes more of a difference than anythig else. Put a set of Falken Azenis on the Si and it will out handle the RSX-S all day long and you'll still have over $5000 in your pocket.
Any reason why you want to keep stock suspension? If you must and you can afford it, the RSX-S is a better choice.
psegs80
51
Aug 17, 2009 05:59 PM
vnvracing
43
Apr 12, 2006 07:15 AM
techn!que
Dec 13, 2004 12:04 PM
