Fluidyne radiator/Fal fans
Advantages? Your wallet will be much lighter
Instead of a Fluidyne (great radiators, but...) get a DelSol VTEC Radiator (dual core and stock fitment). The FAL fans won't do ****.
Good luck.
Good luck.
Good luck.
Good luck.
Fal fans aren't to big of an upgrade from a stock fan, unless you are turboed and you need the extra room for your turbo, and piping etc. Not worth it otherwise. Fluidyne well, Del Sol Dual Core radiator would be your best bet, take a trip to your local wrecking yard.
You'll definitely need some room after that swap. The only gain I see from the fan is more room.
4doorH22
Jan 19, 2002 12:12 PM
