homemade black corners (with black eg headlight)
Old Feb 2, 2003 | 12:11 PM
civic dx's Avatar
Default homemade black corners (with black eg headlight)
made to go with the black headlight. i can make a how-to if you want to know to make them.
Old Feb 2, 2003 | 12:23 PM
NiiS's Avatar
Default Re: homemade black corners (civic dx)
Or we could just use "Search."
Old Feb 2, 2003 | 12:24 PM
SpoonFedHatch's Avatar
not bad bro....coordinates w/the headlights nicely
Old Feb 2, 2003 | 12:34 PM
Jonathan_ED3's Avatar
Default Re: homemade black corners (SpoonFedHatch)
Looks good.
Lemme guess..take apart the corner, paint the inside black, put it back together?
Well that's what I did like 5+ years ago
Old Feb 2, 2003 | 12:54 PM
civic dx's Avatar
Default Re: homemade black corners (hot_EG)
Looks good.
i searched on how to take them apart found nothing. i posted and asked how to take them apart, no reply. now every one is telling me they have done this? it took me 2 hours to make them i thought it was kind of hard.
Old Feb 2, 2003 | 12:55 PM
94HybridEX's Avatar
Looks good.
Bake them in the oven at like 350 degrees for about 10 minutes or until the glue is soft. Pull apart, but leave the glue on there.
Paint the housing or tint the lense, whichever you want. Put peices back in the oven to heat up the glue, and smush back together.
Old Feb 2, 2003 | 12:58 PM
civic dx's Avatar
Default Re: homemade black corners (94HybridEX)
i wish some one would have told that went i asked. i thought if you baked them they would melt.
Old Feb 2, 2003 | 01:05 PM
94HybridEX's Avatar
Just leave them in there until you can separate the lense with a screw driver. You should be fine. I've seen many people do it.
Old Feb 2, 2003 | 01:33 PM
t0p_sh0tta's Avatar
I tried baking mine and they melted, LOOOONG before I could get the lens off.
I just painted the outside and clear coated it. Still looks ok.
Old Feb 2, 2003 | 01:35 PM
94HybridEX's Avatar
Default Re: homemade black corners (t0p_sh0tta)
Really? How long did you leave them in? I believe the key is high heat, for a short length of time....anyone else have any input?
Old Feb 2, 2003 | 01:43 PM
PSU's Avatar
PSU
formerly DxHatchback
get a better picture
Old Feb 2, 2003 | 02:28 PM
The Destroyer's Avatar
Default Re: homemade black corners (DxHatchback)
I thought u could just get tinting and tint them?
Old Feb 2, 2003 | 10:03 PM
Default Re: homemade black corners (94HybridEX 4 SALE)
yep..that's what I did.
~ 475 for like..3 minutes. You can smell the glue start to melt! That's when you gotta take it out I tried 350 etc..took so long it never melted the glue, just the plastic!
Or if you start out with aftermarket corners, most of the time those will pop right off with just a flathead.
BTW, bro, we're not trying to jack your post! Your corners look good, and so do the headlights!
Old Feb 2, 2003 | 10:20 PM
bikeboy80's Avatar
i did it the safe way with a heat gun heating up the edges and getting the glass lense real hot to peel away from the glue
Old Feb 3, 2003 | 03:31 AM
t0p_sh0tta's Avatar
Default Re: homemade black corners (bikeboy80)
I had it on 400-450 for about 4 minutes, but my tabs started to melt. Maybe I had a really cheap set.
I tried the screwdriver after this, but that didn't work either because they had a lip that would just crack.
[Modified by t0p_sh0tta, 7:32 AM 2/3/2003]
JDMlyfestyle
Jan 6, 2006 11:55 AM
94sohcEx
Dec 23, 2005 08:16 PM
straggs42d15
Feb 2, 2005 12:24 PM
JaY-R
Aug 6, 2004 10:16 AM
KOALA YUMMIES
32
May 31, 2003 08:10 PM
