3rd gen 2.0 si with a 4th gen 2.3 si ecu???
Anyone try it or know if the connectors are matching?
We were gonna try it on a friends car to see but thought I would ask first.
Dont even waste your time
plugs will match up if you have an obd1 90-91 lude, but you ahve to repin them because they goto different things. You could try it but it probably woudlnt help much performance wise. The car may just run too rich giving. Its prob better if you try and chip the pk2 ecu.
hey i have a 89 2.0si thats a 5spd with an automatic ECU and it has some shitty surging idle problem that i need to get straightened out, i think its the ecu so i thought i would have to get a new one. but i have an extra 92h23 ecu just laying around i would be willing to plug that bad boy up if it will even run, will it actually plug up to the wiring in the car?
goto a local junk yard/pick a part the cost bout 40 bucks. you can also try http://www.car-part.com
