What is the psi for fuel pressure on a integra?
Old Feb 1, 2003 | 10:29 PM
B18CRacer's Avatar
Default What is the psi for fuel pressure on a integra?
I have a fuel pressure regulator for my gsr...what should the psi should be set to?
Old Feb 1, 2003 | 10:40 PM
GirlyGS-R's Avatar
Default Re: What is the psi for fuel pressure on a integra? (B18CRacer)
It would be more easier to answer your question if you list your mods.
Old Feb 1, 2003 | 11:25 PM
threatcon13's Avatar
New User
Default Re: What is the psi for fuel pressure on a integra? (GirlyGS-R)
what exactly does your "fully built block" consist of?? please list your mods..i find it hard to believe your motor was the first thing u bought for your car..and don't even know what the FPR should be set at.
Old Feb 1, 2003 | 11:33 PM
JforJonathan's Avatar
it should be about 46-48 psi
Old Feb 2, 2003 | 08:18 AM
92lsr's Avatar
Default Re: What is the psi for fuel pressure on a integra? (SiKick)
mines set at 44-46 psi , but im running stock compression
Old Feb 2, 2003 | 09:26 AM
Audio28's Avatar
Default Re: What is the psi for fuel pressure on a integra? (92lsr)
i have mine at 45 psi, when they tuned my car.
Old Feb 4, 2003 | 05:21 PM
98DC2's Avatar
what would a good fuel psi pressure be for the following mods: I/H/E, itm, tb, ignition, & pulleys on an OBD2 gsr converted to OBD1?
The instructions inside of an AEM adjustable fuel pressure regulator recommend setting it between 47-55 psi for a gsr. but it is pretty much mod specific. i just want an idea of what it commonly set at, considering similar mods...thanks.
[Modified by 98DC2, 6:22 PM 2/4/2003]
Old Feb 4, 2003 | 05:23 PM
stick's Avatar
mine is at 50 psi.
Old Feb 15, 2003 | 05:19 AM
Rishiras's Avatar
Default Re: What is the psi for fuel pressure on a integra? (stick)
stick, what setup do you have on your GSR?
Was wondering if I could go also for 50 psi, since We do not have dyno test here on this Island, and my setup is DC header 4-2-1/AEM CAI/FPR/FuelRAIL/Fuelfilter/advance timing at 18 degrees/wheels setup 17" verdict with 215/40 tires.
regards,
RCS
Old Feb 15, 2003 | 06:04 AM
DSayavan's Avatar
Mine is set at 52psi, but I'm running CTR pistons & intake cam.
Old Feb 17, 2003 | 12:30 AM
conesmasher's Avatar
Default Re: What is the psi for fuel pressure on a integra? (DSayavan)
you should run 52psi and have some sort of mechanism to tune it.
Old Feb 17, 2003 | 07:51 AM
zojirushi's Avatar
Default Re: What is the psi for fuel pressure on a integra? (snoballgsr)
what kinda fuel pumps are u guys using with those high fuel pressures?
Old Feb 17, 2003 | 01:01 PM
Cramerox's Avatar
Default Re: What is the psi for fuel pressure on a integra? (zojirushi)
Nothing, should be ok up to 60psi. And i think 60 psi is high....in that range upgrading to bigger injectors is better
hon2984
May 13, 2008 07:55 AM
EGsLeePiN
Apr 11, 2005 07:37 PM
honda9369
Sep 9, 2004 07:04 PM
THE94GSR
Mar 2, 2004 12:10 PM
toooslow
Jun 13, 2003 04:06 PM
