Blown motor, or just head gasket????
Old Feb 1, 2003 | 07:38 PM
leprechaun117's Avatar
Default Blown motor, or just head gasket????
ok, my car was over heating like crazy, and i was forced to keep driving, so i "blew" my engine. i took the head off today, and i am in the middle of replacing my head gasket. what else may have gotten f*cked up?? i know i didnt throw a rod and its not seized, but what else could be broken??
[Modified by leprechaun117, 8:40 PM 2/1/2003]
Old Feb 1, 2003 | 07:42 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Blown motor, or just head gasket???? (leprechaun117)
I would drop the oil pan and check all your bearings. When the car's that hot for that long, oil isn't doing much as far as lubrication goes. Check the bearing, check the deck and head for "trueness"-you could have possibly warped either, which probably happened.
Old Feb 1, 2003 | 07:46 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Need more information as to how the car is acting now. Everything from the color of the exhaust gases to the feel and look of the fluid inside the head.
Old Feb 1, 2003 | 07:51 PM
civperc's Avatar
did you notice any smoke coming from your exhaust and/or engine bay?
no matter if the head gasket is the problem or not, it's good you're replacing it anyway.
Old Feb 1, 2003 | 08:03 PM
Default Re: Blown motor, or just head gasket???? (untensadude)
ok, its not running, the head is off, before it died there was a whole lot of white smoke from the exhaust and the engine, plus it blow a hole in the top of my radiator. the oil looked normal, black. and the coolant was darker than normal, and all foamy, cause i blew my head gasket.
Old Feb 1, 2003 | 08:42 PM
tominos's Avatar
i would check if your head is warped or not, use a straightedge and place on the head, if all is even then its still good, if not, you have to machine it.
Old Feb 1, 2003 | 10:56 PM
SikofFalln's Avatar
Default Re: Blown motor, or just head gasket???? (tominos)
Check for burnt valves and a warped head. A freind of mine had the same thing go wrong with his boosted D16Z, the head had a few bad valves. He slapped on a newer head and was good to go.
Old Feb 2, 2003 | 02:14 AM
NiiS's Avatar
Optimistically, you probably just blew the head gasket. Either way, that head should go to the shop to verify what damage you incurred, and that will answer your Q's. The good news is you now have the opportunity to do the H2o pump, T-belt, and all vital gaskets while you're in there, I mean you may as well just hit it while you're there, no?
G00d luck, y0
Old Feb 2, 2003 | 02:46 PM
Default Re: Blown motor, or just head gasket???? (sinister)
ok, i got it running. all i did was change the head gasket, i was gonna do the timing belt, but then i realized how you have to do it, so i left the old one on. i patched the radiator with some of that dual-tube epoxy, and it seems to be doing fine. only thing is that theres a knock now, could i possibly be a rod (i hope not!!) thanks.
Old Feb 2, 2003 | 02:49 PM
acydphryck's Avatar
overheating huh??? did you check the radiator fluid level? how's the thermostat? was it bogging down? any clanking noise from the motor? how's the water pump? were u leaking oil between the head and the block? why did you pull the head off? any leaks from the block at all? need more info...
Old Feb 2, 2003 | 02:58 PM
Default Re: Blown motor, or just head gasket???? (acydphryck)
it had plenty of fluid, before it boiled off, and i changed the thermostat last weekend. it bogged right before it stalled/died. i pulled the head off because like 40 people told me i blew my head gasket, and cylinder #3 had the metal part of the gasket burned all the way out. it wasnt leaking, just dead, but its all running now, no more problems, except that its slow, but a d16z6 will help with that.
lilshady6796
May 23, 2009 11:21 AM
DreamCatcher
Nov 27, 2005 02:28 PM
Squirtin EGsr
17
Sep 26, 2005 09:13 PM
GDM Z28
May 6, 2004 04:28 PM
GSR4door1
Apr 24, 2004 08:02 AM
