Brake fluid leak?
My cars brake pedal pushes all the way to the floor before any stoppage. They've been bled a few times, from rear right, rear left, front right, front left (non-abs), but still no pressure behind the pedal. The reservoir cap was removed during bleeding, and the pedal held to the floor each time, and a steady amount of fluid was pushed out when the bolts were tightened on the bleeders. I havent seen any leaks around the car. Anybody have experience with this? Could it be the master cylinder? Thanks in advance.
