EX Cluster into DX? plug and play?
I have a DX and want to put an WX gauge cluter for the Tachometer it has, would it be completely plug and play? or is there anyway to make it work in there?
thanks
thanks
Plug and play, but i warn you before you try it, I was retarded enough to try this once, and realized i couldnt change the miles...... so I owned myself.... but i sold it for more than i got it for so it all turned out ok
and it is plug and play for both EG's and EK's. Like an 92-95 EX cluster will fit into a 92-95 DX, and a 96-00 EX cluster will fit into a 96-00 DX, correcto?
we put my 92 SI cluster into my friends 94 dx, so you should be good. just be careful not to break the clips on the cluster. that sucks.
to doing things when you don't know what you are doing.
so a 96-00 EX cluster should fit a 2000 cx too right?
Hey bud I did it myself and I'm polish. First you take the two bezel screws up at the top out. That sleeve type thing pops right out. Then unscrew the bottom corners. Make sure you don't drop the screws in the car. Pull the cluster and unplug the three wires in the back. Take your ex cluster and plug the three wires into that one. Turn on the car and make sure all the gauges work tach, speedo and the gas with temp. I did this myself and the place I bought from gave me a cluster with a bad temp gauge. Since I took the cluster apart to put in my speedo they said it was my fault and there goes 100 bucks. Know I have a tach, my speedo and the gas gauge but no temp. I'm gonna switch back to my old one now and put a over size tach on my a-pillar probably. Overall very easy swap and should take no more then a half hour. Oh yeah this was for a 96 cx hatch.
89 EF Si
Mar 14, 2005 08:53 AM
itsJDMyo
Aug 26, 2003 09:51 AM
Hatebreed215
Jan 18, 2003 10:14 PM
