How do I get the rotor screws off?
Old Feb 1, 2003 | 03:31 PM
Super7's Avatar
Default How do I get the rotor screws off?
Impact screwdriver does nothing.
Can I drill it? If so, how? Special bit needed?
Thanks guys.
Old Feb 1, 2003 | 03:38 PM
Dropspeed's Avatar
Default Re: How do I get the rotor screws off? (Super7)
Good Luck, I had to drill and retap the last time I tried to remove it.
Mattj
Old Feb 1, 2003 | 03:41 PM
kkim's Avatar
https://honda-tech.com/zerothread?id=393596
Old Feb 1, 2003 | 03:44 PM
Super7's Avatar
Default Re: How do I get the rotor screws off? (kkim)
thanks. didn't find that in my first search.
heading to Home Depot right now
Old Feb 1, 2003 | 03:54 PM
typealex2's Avatar
Hit the driver harder.
Or you can drill it out with any hss bit.
This may be obvious but make sure you have the driver in the right rotation.Ihave yet to see a screw that would not come out with a impact driver,provided the slot was not screwed.
May take 5 or 6 good wallops!
Old Feb 1, 2003 | 04:33 PM
96IntegraRS's Avatar
Default Re: How do I get the rotor screws off? (typealex2)
You have to drill them out. It took me 5 high speed steel bits to do them. I still haven't replaced them yet. Good luck, this can be a real bitch. I did use the inpact driver at first but to no avail.
Old Feb 1, 2003 | 06:04 PM
TypeR 01 886's Avatar
Default Re: How do I get the rotor screws off? (96IntegraRS)
wholy crap.... do they have to do that all the time. Sounds pretty common, I need to have a wheel stud replaced, acura was going to do that..... I hope that they dont drill them
Old Feb 1, 2003 | 06:46 PM
SamC's Avatar
Default Re: How do I get the rotor screws off? (TypeR 01 886)
where do you guys purchase the impact screw driver?
Old Feb 1, 2003 | 06:49 PM
RTW DC2R's Avatar
Default Re: How do I get the rotor screws off? (SamC)
I got mine at Sears, $26. It didnt work, and will need to drill it out anyway
Old Feb 1, 2003 | 06:55 PM
Super7's Avatar
Default Re: How do I get the rotor screws off? (RTW DC2)
The screw turns the normal way, right? It's not a reverse threaded screw or anything, right?
Mine was $13 at autozone, but it dont work...
Old Feb 1, 2003 | 07:00 PM
Dr Pooface's Avatar
This is how it is done:
Take a ball peen hammer, you know, this one:
Hold the round side on the screw head, and hit the flat side with another hammer. Hit it hard. The shock will loosen it, and you can now take the screw out with a normal screwdriver. I Broke my impact driver on that screw before I tried the ghetto trick. Keep It Simple, Stupid.
Old Feb 1, 2003 | 07:44 PM
SUPERAUTOBACS's Avatar
Default Re: How do I get the rotor screws off? (Dr Pooface)
I had to pry it off with a large pry bar and it snapped the head or the screw right off. I guess this would be ur last option....i had no choice with a track day the next morning.
Old Feb 1, 2003 | 09:56 PM
hecklervtec's Avatar
From: Formerly WI, now back in NorCal and everywhere else
Default Re: How do I get the rotor screws off? (SUPERAUTOBACS)
The thing I get a kick out of with these screws is the Helm's manual says those screws are suppossed to be in there with 6-7 lb/ft of tourque. The screws certainly didn't come from the factory only torqued to that. Had to beat two of them out with impact driver first time I changed rotors.
Old Feb 1, 2003 | 10:06 PM
SurferX's Avatar
Default Re: How do I get the rotor screws off? (hecklervtec)
Yeah my impact driver got most of them except for one. Nothing a good drill and titanium coated bit couldn't handle.
Old Feb 1, 2003 | 10:08 PM
HondaJon's Avatar
Default Re: How do I get the rotor screws off? (SurferX)
Impact driver from sears did the job on my friends G2 that had some old rotors on it.
Hit it a few times and turn, and before you know it, the screws are loose.
Great tool, perfect for the job
JP
Old Feb 2, 2003 | 02:31 AM
Art Vandeleigh's Avatar
Default Re: How do I get the rotor screws off? (HondaJon)
evey man should have one of these in his arsenal.
[Modified by Art Vandeleigh, 11:32 AM 2/2/2003]
Old Feb 2, 2003 | 07:16 AM
Veritas-Aequitas's Avatar
Grumpy Old Man
If you start to hear funny noises from your car, especially in reverse you know why
Old Feb 2, 2003 | 07:20 AM
Batoutahell's Avatar
Default Re: How do I get the rotor screws off? (ReBornGSR)
I wasn't aware there were any bad side effects from leaving the screws out. I removed mine 8 months ago. Shouldn't the wheel hold the rotor in place?
Old Feb 2, 2003 | 10:00 AM
dustin's Avatar
Default Re: How do I get the rotor screws off? (Batoutahell)
I had no screws on the rotors in my integra for 2 years without any problems. They don't do anything when the wheel is properly torqued in place.
Old Feb 2, 2003 | 10:15 AM
sneakychaos's Avatar
Default Re: How do I get the rotor screws off? (Art Vandeleigh)
Art - obviously I dont have one of those in my toolbox, so what is it.
Old Feb 2, 2003 | 10:49 AM
SurferX's Avatar
Default Re: How do I get the rotor screws off? (sneakychaos)
It's the impact driver everyone has been talking about. Hit it with a hammer and it will apply up to 200 lbs-ft of torque so it says on the package. I have one of these too and it worked for the most part. However there was one screw for me that was in so bad that all the impact driver did was strip it faster.
Old Feb 2, 2003 | 11:06 AM
It's the impact driver everyone has been talking about. Hit it with a hammer and it will apply up to 200 lbs-ft of torque.
bingo.
Old Feb 2, 2003 | 02:30 PM
DMF's Avatar
DMF
I used the impact driver on my last change. Definatly the tool you want in your box.
Old Feb 2, 2003 | 02:33 PM
neato. thx.
Old Feb 2, 2003 | 06:18 PM
Grumpy Old Man
Default Re: How do I get the rotor screws off? (dustin)
I also thought this as well. But shortly after I started running my integra with no screws in the rotors and properly toqued wheels I started to get a sound like a wookie was stuck under my car. I made a thread about it in The Type-R forum but they couldn't come up with any reasons as to what was making the noises. After hours of searching the only thing that I could come up with was putting those screws back in and the noise went right away
