Where to find 10lb flywheel
Old Feb 1, 2003 | 11:50 AM
jonoknut's Avatar
Default Where to find 10lb flywheel
like the topic says, i see a lot of 8.5 or 8.8 and 12 pound flywheels, ive only heard one in the 10's mentioned once or twice, I can't seem to find one, does anyone know who sells them? thanks
Old Feb 1, 2003 | 11:52 AM
MooreBoost's Avatar
Default Re: Where to find 10lb flywheel (jonoknut)
I think thats because the 8lb'ers are race only, and the 12's are very streetable. Mine is too light, its a Fidenza unit, but it lets the car die sometimes when I clutch and let off the gas quickly.
gmoore
Old Feb 1, 2003 | 02:50 PM
locass316's Avatar
Default Re: Where to find 10lb flywheel (gmoore379)
i had a 10lb chormoly one but I sold it though....
Old Feb 1, 2003 | 02:55 PM
gsxr's Avatar
Default Re: Where to find 10lb flywheel (locass316)
my jun lightweight flywheel weighs in at 10lbs
[Modified by gsxr, 3:57 PM 2/1/2003]
Old Feb 1, 2003 | 03:59 PM
tegasaurus's Avatar
Default Re: Where to find 10lb flywheel (gsxr)
well jonny... looks like you're pussying out again with what you're putting on your car.
you drove my car with the fidanze and said ti was easy to drive. don't you remember? that's why i say, get the fidanza... but if you want to get a 10 lb one... zex has a 10 pounder... but it's chromoly... now let me tell you about chromoly vs aluminum
When Aluminum gets too hot from driving at extended high RPM, it will warp (this only under extreme conditions). As a result, you need to get a new flywheel.
when Chromoly gets too hot from driving at extended high RPM, it will split and shatter into about 100 pieces (this is onl,y under extreme conditions). As a result, you will die because the pieces will shatter your tranny case, most likely cut your brake lines, split your radiator, destroy your clutch, puncture your oil pan, etc etc. Since you were at a high rpm (most like in 3rd or 4th gear because of the high stress loads), you will be traveling at 60-90 mph... consider yourself a rollercoster without brakes.
what do you want? a lightweigh flywheel that could possibly keep you from dying, while at the same time being faster tha nthe chromoly one, or do you want one thats for pussies (ie 10 or 12 lbs vs 7) that can utlimatly total your car and possibly your life?
the choice is your jon. Honestly i'd say go with fidanza, because i KNOW you can handel it and i don't want my friend to die, let alone lose a member of the teg club
-Ryan
Old Feb 1, 2003 | 04:19 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
gmoore
Race only? Uh try again. I also have a 7.5lb Fidanza flywheel and it is COMPLETELY STREETABLE. In fact if the car came like this stock I doubt anyone would really complain. Get a Fidanza and be happy.
Old Feb 1, 2003 | 06:02 PM
Rory Breaker's Avatar
Default Re: Where to find 10lb flywheel (ActiveAero)
The Fidanza is TOTALLY streetable...the myths about flywheels being too light are just that....myths!
Old Feb 1, 2003 | 06:24 PM
MooreBoost's Avatar
Default Re: Where to find 10lb flywheel (newgsrdriver)
My car dies because of my flywheel, it didnt do it before install, and it started immediatly afterwards. IMO, mine is too light, it lets the car die, maybe its only on mine, but it gets annoying.
gmoore
Old Feb 1, 2003 | 07:42 PM
neo1z's Avatar
why not try a happy medium w/ TODA at 9 lbs
Old Feb 1, 2003 | 08:20 PM
threatcon13's Avatar
New User
Default Re: Where to find 10lb flywheel (tegasaurus)
Thanks for the analogy mr. wizard, but I highly doubt your friend will be doing any N1 endurance races ( EXTREME CASES AHEM) which would cause this kind of situation to happen.
Old Feb 1, 2003 | 10:09 PM
integraautox's Avatar
Default Re: Where to find 10lb flywheel (_JASON_)
go with the fidanza john you will regret it if you dont
i have it and absoulty love it
Old Feb 1, 2003 | 10:34 PM
jonoknut's Avatar
Default Re: Where to find 10lb flywheel (integraautox)
ok im convinced on getting a lighter one if eveyrone else can manage it, but is there a difference in say the ACT for 250 or less and the fidanza for 300?
ps. bobby whats ur SN?
Old Feb 1, 2003 | 10:47 PM
tegasaurus's Avatar
thanks for the anolgy mr. wizard, but I highly doubt your friend will be doing any N1 endurance races ( EXTREME CASES AHEM) which would cause this kind of situation to happen.
anytime
actually you, the wizard's faithful assistant, brought up a good point, i am going to correct myself. It's not the spirited driving that breaks it, but the high clamping force of an upgraded clutch, for instance a XTa6 (xtreme pressure plate, 6 puck disc).
apparently it's a cold day in hell, because i stand corrected .
P.S. no need for name calling
-Ryan
Old Feb 1, 2003 | 10:59 PM
New User
anytime
-Ryan
sorry about the name callin.
1Bluegsr
Nov 25, 2011 05:05 PM
tekstyle
Dec 16, 2007 06:48 AM
90AccordVTEC
Oct 21, 2005 05:29 AM
itrQ
May 30, 2002 03:12 PM
Spocko
Apr 18, 2002 05:59 AM
