Help on Lower Control arm bushing
Old Feb 1, 2003 | 09:36 AM
JdmH22Acorn's Avatar
Default Help on Lower Control arm bushing
I own a 1994 honda accord lx and i was doin my suspension for a 3rd time. i was putting on my apexi ws coilovers when i get to the lower control arm and the bolt was frozen inside the bushing...so i had to take out the whole bushing just to get the bolt out. Every where i call said i need to buy a whole new control arm. i was just wondering if engery suspension makes one or it comes in a whole kit thanks guys... I hate winter in New england
Old Feb 1, 2003 | 12:45 PM
4doorH22's Avatar
Default Re: Help on Lower Control arm bushing (JdmH22Acorn)
That is a miracle you got any stock LCA bushing out.
Anyhoo, the stock bushings usually have to be pressed IN or OUT with a press capable of several tons of force (or a sawsall (SP?) and a blowtorch). Aftermarket bushings like Prothane or Energy Suspension should slip right in. If you want to use an OE bushing, you'll probably have to remove the whole LCA and have new OE bushings pressed in.
http://www.nipponpower.com/suspensio...x_bushing.html
Old Feb 1, 2003 | 01:57 PM
Hondaaccordvtec's Avatar
Default Re: Help on Lower Control arm bushing (4doorH22)
If you want OEM bushings, I suggest giving Manchester Honda a try. http://www.manhonda.com - I know they sell them individually because I have asked in the past.
Old Feb 1, 2003 | 02:30 PM
urbanlegend21's Avatar
New User
that is probably why the bolt was frozen to the bushing
Old Feb 6, 2003 | 05:35 PM
lshybrid195's Avatar
Default Re: Help on Lower Control arm bushing (urbanlegend21)
damn i havin the same problem as u **** bolt is frozen stuck in there and i have to change my shock 2
Old Feb 6, 2003 | 06:56 PM
Stew Pidasso's Avatar
Default Re: Help on Lower Control arm bushing (lshybrid195)
From past experience, I just buy the bushings before I attempt the install on any car over 5 years old.
Old Nov 19, 2004 | 06:45 AM
Mike813's Avatar
Default Re: Help on Lower Control arm bushing (Stew Pidasso)
bringing this back from the dead, would a regular balljoint press be able to get the sucker out???
justBrowsing
Honda Civic (2001 - 2005)
Jan 30, 2012 12:07 PM
Space Cadet
Suspension & Brakes
Oct 29, 2010 04:55 PM
clarkekent13
Suspension & Brakes
Oct 7, 2005 06:48 AM
