whats the difference between si an dx brakes
Old Feb 1, 2003 | 08:03 AM
riceboyEFsi's Avatar
Default whats the difference between si an dx brakes
does it have bigger rotors or is the caliper different . Are the brake pads themselves the same ? thanx every1 >>> evan
Old Feb 1, 2003 | 08:35 AM
Owhite3's Avatar
Default Re: whats the difference between si an dx brakes (riceboyEFsi)
The 90-91 CRX Si's have bigger calipers and rotors. the 91 Civic EX sedan has much larger ones, however you will have to swap knuckles to use them
Old Feb 1, 2003 | 09:10 AM
Default Re: whats the difference between si an dx brakes (Owhite3)
i have a civic hatch si , not a crx. the problem is a complete si spindle is not readily available in a junk yard . My original spindle on my si was fucked , I needed a hub bearing , a hub and a lower ball joint . So what i did was i got the spindle redone w/ a new lower ball joint and new hub bearing . Now this is where it gets crazy , the hub that i got was from a dx which actually fit my ls axels so i used the dx hub on the si spindle . so what do i need to convert the dx brakes to si
thanx guys >>> evan
Old Feb 1, 2003 | 04:09 PM
(in case any 1 cares )just figured out the calipers r different and i think the rotors r as well .
ridgeapd
May 27, 2010 04:07 PM
Serdar
Aug 14, 2005 05:35 PM
MAD SCIENTIST
Apr 19, 2004 06:05 PM
CRX Si
Apr 25, 2003 09:44 PM
crooked muffler
Jan 16, 2003 08:04 AM
