b18a in a 90 si wiring?
Old Jan 31, 2003 | 10:41 PM
xsellxoutx's Avatar
Default b18a in a 90 si wiring?
i have a 88 hf with a 90 civic si motor/tranny/ecu/etc. what wiring do i need to do?
Old Feb 1, 2003 | 12:04 AM
Jdm_Rice_Monster's Avatar
Default Re: b18a in a 90 si wiring? (xsellxoutx)
its all the same. Take off your old harness put it on your new motor. Then plug in your new ecu, and your good to go.
Old Feb 1, 2003 | 06:01 AM
rioninja's Avatar
If its your first swap, then you'll notice its a tight fit in some places for the wiring. It does fit though, like stated above.
Easiest way to do it, is to pull the stock motor with the wiring still on it, just dissconnect the harness on each shock tower. then sit the two motors side by side and switch it over while its out of the car.
Old Feb 10, 2003 | 08:28 PM
xsellxoutx's Avatar
Default Re: b18a in a 90 si wiring? (Rioninja)
there was an extra plug on the back of the b18a block that the crx harness didnt have what should i do about it?
SwissChEz82
Mar 31, 2004 06:26 AM
daflipcyde
Feb 23, 2004 05:54 PM
CRXracer88
Mar 28, 2003 07:40 AM
xsellxoutx
Feb 12, 2003 03:55 PM
Charlie Moua
Feb 27, 2002 06:11 PM
