my VSS gear problem...
Old Jan 31, 2003 | 08:12 PM
baonest1's Avatar
Default my VSS gear problem...
well ive been on this case for a while now. im at the point where i am about to call honda of japan and order from them.
that is my problem. i cant find the JDM gear anywhere.
the LS gear fits like the JDM one does. but it has a larger diameter and i dont want to mess anything up. if anyone has any knowledge about this please share.. can i replace the JDM one with the LS??
thanx
Old Jan 31, 2003 | 10:08 PM
sgT's Avatar
sgT
Default Re: my VSS gear problem... (baonest)
get me a measurement on the diameter.
Old Feb 1, 2003 | 12:55 AM
onyx00's Avatar
Default Re: my VSS gear problem... (sgT)
I thought you said the stuff wa the same.
Old Feb 1, 2003 | 06:30 AM
baonest1's Avatar
Default Re: my VSS gear problem... (onyx00)
they are for the USDM gears..
sgt. ill get the measurements as soon as i can.
edit: for the JDM its 16mm in diam. and the LS looks to be roughly 22mm
thanx
[Modified by baonest, 10:47 AM 2/1/2003]
Old Feb 1, 2003 | 08:34 AM
sgT's Avatar
sgT
im pretty sure ALL the speed sensors i have look lik ethe one on the left.
whats wrong with yours now?
Old Feb 1, 2003 | 10:41 AM
baonest1's Avatar
You can see it kind of in the picture.. there is a fork type at the top of it.. one of the sides broke off.. so insdead of "U" its a "L" at the top.
The shaft of both gears are the same. just the "gear" itself is different.
When im gonna start the motor.. should i use the LS one? or should i just go ahead and see if i can get it from a JDM dealer.
thanx
edit: here is a pic:
[Modified by baonest, 2:44 PM 2/1/2003]
94DB8
Nov 27, 2007 09:14 PM
joejoe23red
Oct 23, 2005 08:32 PM
Shongku
Jun 1, 2004 09:26 PM
typeass
Apr 4, 2004 11:25 PM
baonest1
Jan 31, 2003 07:04 PM
