Header install question
Old Jan 31, 2003 | 08:01 PM
jasonb's Avatar
Default Header install question
I know most one piece header installs require you to drop the front crossmember. I was just wondering if the radiator was removed as well as the upper support in front of the rediator, would you still be required to lower the crossmember? My radiator is out of the car right now, so I would rather deal with that then the crossmember.
Old Jan 31, 2003 | 08:27 PM
Toptul_Honda's Avatar
New User
Default Re: Header install question (jasonb)
if i can remember correctly. the lower radiator suppoer is on the crossmember.
correct me if im wrong
Old Feb 1, 2003 | 09:22 AM
andrew dc's Avatar
Default Re: Header install question (G2-Rex)
x-member is an x-member.. rad support is close but not attached... you may need to just loosen the x-member if you are lucky, but its easy to put on and take off.. send the header from the bottom up (from my experience).
HTH
Old Feb 1, 2003 | 11:47 AM
Rywire's Avatar
Default Re: Header install question (CRX25)
True, you will definately have to remove the x member to fit a 1 pc header. It not hard though, just takes a few extra minutes. Def. install from bottom. Ryan
nholmes
Jan 10, 2006 09:07 AM
sleepin91teg
Jan 22, 2004 09:54 AM
non-VTEC
Oct 27, 2002 06:26 AM
