My car won't start AHHHHH!!
OK so it was driving fine yesterday parked it in the garage last night. I got up this morning and the damn thing won't start. It cranks but won't turn over. Suggestions?
does it sputter or anything? have gas? um, make sure there is no outside noise, then turn the key to on and listen to see if you can hear your fuel pump prime the line. It will be a faint noise, like a little hum, only lasts a few seconds. If you can hear that, then I will try to think of some more stuff for you to do.
weird that you parked it last night and now it doesn't start. Do you have any friends that would play tricks on you? like pull spark plug wires and what not? If so, check all those and check that the coil wire is on too.
Rule-1...check for fuel.
Rule-2 check for spark.
Sounds like your problem is ignition???
See if it will spark from the plug wire to the chassis.
Just be careful.....use a good long screwdriver with an insulated handle.
I know for a fact an igniter or a coil will die on you with no notice at all.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
im also guessin your ignition...prob your coil in your distrubutor...my car didnt start last time because of that...just test out your sparks
I dunno if this is a coincident or not but why is everyones coils and ignitions going bad like right now. Does it have to deal with it being winter and the cold affects those parts somehow. Just wondering....
Clutch in?
Edit: Damn Typos!
[Modified by Hatchy-Ownzjo0, 1:19 AM 2/1/2003]
from past experience,..if the battery was drained then your car wouldnt even crank,...like someone had said earlier,...put the key in and turn to the on position,..if you cant hear the fuel running then check the fuse for the fuel pump,..its the same one as your SRS fuse
Good Luck.
Good Luck.
Well I don't know what the hell happened but it started. I didn't touch a thing. My friend came over to help me and I got in and it started.
don't know. oh well it runs. just needs to get through winter then the B18c can go in.
thanks guys
thanks guys
civicturbo22
Jan 25, 2005 05:43 AM
