b16 for my 96 ex
Please no flamers this is a TECH question.
did a search.
I'm planning to do b16 swap in my 96 civic. I don't understand the concept of obd's but what i understand that their're wiring codes for different
models. I believe i have a obdII car, (please correct me if i'm wrong anywhere). So i have to get a b16A2 because that is OBDII, if i choose to go with a b16A1 i would have to switch out my distributor, and starter and other such stuff (am i correct)
Thanks for you help
did a search.
models. I believe i have a obdII car, (please correct me if i'm wrong anywhere). So i have to get a b16A2 because that is OBDII, if i choose to go with a b16A1 i would have to switch out my distributor, and starter and other such stuff (am i correct)Thanks for you help
b16a's from Japan are OBD1, B16A2's are in the Del Sols and B16A3's in 99-00 Si's are OBD2. Each ecu has different sensors to look for and are basically separate programs. OBD2 looks for a knock sensor, 2 o2 sensors, etc.
Edit- 96 and up Civics are OBD2, 96 and up Tegs are OBD2, except 97 R, which is OBD1
If you get an OBD2 engine, which you should for easier tuning, you'll need an OBD2 to OBD1 wiring harness to run a OBD1 ECU
Edit- you have a OBDII car, my bad...don't need conversion unless you drop OBD1 in
[Modified by Emerica, 11:38 PM 1/31/2003]
b16a2's are from Japan, and are OBD1, B16A3's that are in the Del Sols and 99-00 Si's are OBD2.
Ok, i'm kinda lost here.
So which engine would i need to work with my civic, without swaping out parts.
I don;'t know if they are ONLY from Japan, but they were the OBD1 B16 engines. B16A1 was the first gen B16 which is OBD-0 and the cable tranny. The B16A3 is the only stock B16 engine available in the US, in the del sol, si, etc.
i won't need to change the dist. and other stuff.
[Modified by Emerica, 6:51 PM 1/31/2003]
For clarification an engine out of an Si is of course a B16A2 as stated on the block and OBD-II so obviously this will work or you can go with a JDM B16A out of a 96+ Civic and that will work. You don't have to stay OBD-II but it's illegal to have a street car with an engine older than the car in it in most places. I know that you can reuse your EX harness on the B16A engine, and your option for the ECU are:
1) Get an OBD-II to OBD-I harness and run an OBD-I ecu which you can rechip
2) Get a JDM OBD-II ecu
These are the two easiest options IMO...being that I read the ECU for a 99-00 Civic uses different ECU plugs that the 96-98 Civic so your EX wiring harness might not plug up to an Si ECU. Someone correct me where I am wrong.
[Modified by Jay-C, 12:02 AM 2/1/2003]
99-2000 si is obd2b
your car is obd2a.
compatibility is an issue.
your car is obd2a.
[Modified by sshaikh01, 1:35 AM 2/1/2003]
Alright, I'm going to tell you what you need to do. Listen to me, and only me.
There are two ways that you can solve your ecu question.
1. Find an OBD2 b16a ecu (96-97 del Sol) or a JDM ITR ECU (96-97)
2. Chip an OBD1 civic ex/si ecu and run an ecu jumper (recommended)
Those are the easiest things to do.
When you do the swap, you're going to use your EX harness.
Use this for further info: http://mycivic.kicks-***.net/6gen/
btw, the 99-00 Si came with the B16A2
get a 99-00 Si engine. You need to rewire the CKF and extend the primary O2 sensor wires on your EX harness. Other than that, there are no other wiring modifications necessary, it will plug in 100%. I run a 97 Del Sol vtec P30 and it runs great.
I installed a 97 B16a2 from a del sol in to my 96 coupe, it was straight plug and play...a monkey could do it.
how quick is your car compared to a gsr
me
