gapping plug
Old Jan 31, 2003 | 03:14 PM
jeebusm3's Avatar
Default gapping plug
i have never gapped a plug before...in case you were wondering.
I have one of those ramp-type circular gapper things. Do I just put in in-between the electrode and ground thingy and turn it until it gets to my proper gap?
[Modified by gtravsr, 12:23 AM 2/1/2003]
Old Jan 31, 2003 | 03:26 PM
jeebusm3's Avatar
Default Re: gapping plug (gtravsr)
come on...all you guys know this.
Old Jan 31, 2003 | 05:43 PM
Flexmyrex's Avatar
yes just go through them w the gappin tool, make sure its not too tight or too free either, if the gap is too big just tap the end of it on a table or whatever to get the gap smaller.
keep your old plugs in case your car doesnt run right
Old Jan 31, 2003 | 06:34 PM
rotten's Avatar
For the best accuracy, ditch the 'ramp type circular' gauge. Go get a circular wire loop ones, that basically look like a coin with staples of various sizes sticking out on the edge. They also have a little tool on them usually to adjust the electrode. Like a buck at an auto parts store.
So take the wire and run it through the gap, should feel a very slight friction if you have it right. If it is too big or too small, use the little tool that is on the gapper.
Basically you take the slot on the tool (looks kinda like an 'F'), and put the electrode into the little slot in the tool... you can then easily bend the electrode down or up easily and accurately.
-k
Old Jan 31, 2003 | 10:44 PM
dilligaph's Avatar
Default Re: gapping plug (red240ne)
most plugs come pregapped.
Old Feb 1, 2003 | 12:24 AM
jeebusm3's Avatar
Bwahahahahhaha. I've never seen a question this dumb on a forum before.
Thanks *******. I have never done it before. I know it's easy, but I wanted to do it right. Excuse me for never doing such a simple task.
Old Feb 1, 2003 | 12:35 AM
texan's Avatar
Well you're certainly making friends. I've never seen such useless comments in this forum before either, in case you were wondering .
David do
Mar 14, 2017 04:56 AM
PsXtreme
Jun 26, 2016 01:43 PM
xSOHC
Oct 15, 2013 12:08 PM
i-want-a-crx
Mar 4, 2008 06:21 AM
blah13
Apr 25, 2003 08:51 PM
