So you got your integra LS swap, but no teg throttle cable? civic mount won't work!
Old Jan 31, 2003 | 03:09 PM
g_man80's Avatar
Default So you got your integra LS swap, but no teg throttle cable? civic mount won't work! 56K?
This thread is actually per an IM conversation that I had with EF9_Sir about doing an LS swap in 92-95 civic.
Like me, some people get their swap, but the throttle cable isn't include and the civic one won't work for what could be various reasons. In my case I recieved a '96 b18b, but no LS throttle cable. I didn't want to have to go hunt junk yards or wait and order the right one. I noticed that my cx cable was long enough and thought I could just use my civic throttle cable mount (pic #1) on the LS intake mani. Unfortunately the bolt pattern and location were way off. I also couldn't use the integra mount because of where it held the cable (the exposed cable wasn't long enough to reach the TB). At this point I was sort of screwed. Fortunately my friend and I were able to make our own mount (pic #2,3,4) out of aluminum (he's a good fab. and welder).
We basically attached the cable to the TB and held it at a location that let it operate normally. Using just a flat piece of alum. we marked the mounting location, drilled, and then continued by deciding where to bend the alum to get the proper mounting location. It was nice that the cable had the threaded end for fine adjustment afterwards. The main difference between the LS and civic cables that I noticed was the extra length of exposed cable on the LS which allowed it to be held to the left of the mounting holes and not the right, which is what we had to do to make the cx cable work.
If you are having trouble understanding or visualizing what I'm talking about just look at the mount we made and imagine it flipped to the right (180 degrees). You would be trying to hold the cable about 5" from where the civic cable wants to be mounted (not good). That's what the LS mount looked like. Unfortunately I was unable to locate the orignal LS mount for a good comparison, but I hope this helps.
CX cable mount and intake manifold:
Homemade mount for CX cable on LS manifold:
Homemade:
Homemade:
G
Edit: I hope the pics are sized ok, maybe a little too big
[Modified by g_man80, 7:18 PM 1/31/2003]
Old Jan 31, 2003 | 03:36 PM
JV's Avatar
JV
Who?
Default Re: So you got your integra LS swap, but no teg throttle cable? civic mount won't work! 56K? (g_ma
Nice write up...
I just bought an LS cable at the dealer. It was only like $30...
Old Jan 31, 2003 | 03:40 PM
dwnthehatch's Avatar
You should sell them.
Old Jan 31, 2003 | 03:43 PM
Patrick's Avatar
I always thought the ls throtle cable came in from the passenger side much like the gsr but just at a striaght angle, so didnt you have to change the pulley?
Old Jan 31, 2003 | 04:03 PM
g_man80's Avatar
Damn, that might have just been easier.
I'm not sure about all years of the LS, but the mount that was on mine when I got it made all indications that the cable swung around from the driver's side like the civic's. Perhaps on the 92 or 93s it came from the pass. side, I'm really not positive. I know when we did this I didn't have to change the pulley.
G
EDIT: Here is pic (not mine, actually a GSR engine). This is what the mount that came with the LS actually looked like. It's hard to see, but the cable is a few inches longer and it actually mounts closer the right side of the mani as apposed to the mount that we made for mine.
[Modified by g_man80, 8:14 PM 1/31/2003]
Old Jan 31, 2003 | 04:15 PM
JV's Avatar
JV
Who?
Yeah, but creativity beats "lazyness" anyday...
Old Jan 31, 2003 | 04:17 PM
g_man80's Avatar
And not only is aluminum lighter, but it's sooooo purdy.
Old Jan 31, 2003 | 05:06 PM
wizzards581's Avatar
what about gsr swaps??? the throttle cable goes back towards the driver..
Old Jan 31, 2003 | 08:29 PM
g_man80's Avatar
Sorry, can't help you there.
bori bori
Dec 27, 2009 01:25 PM
ryanevansoh
Feb 18, 2009 06:26 PM
Touge Tuning
Apr 20, 2006 10:07 AM
EKIM NART
Sep 2, 2004 04:37 PM
Dancing is Forbidden
Jan 29, 2003 03:53 AM
