best chip for p28 to run DOHC?
Old Jan 31, 2003 | 10:01 AM
dingusjt's Avatar
Default best chip for p28 to run DOHC?
what is the best chip to modify the p28 ecu to run a b18b/c engine? or should i just get the ecu that pertains to it?
Old Jan 31, 2003 | 10:03 AM
kenji's Avatar
25 Year Member
Default Re: best chip for p28 to run DOHC? (dingusjt)
I offer ECU chipping services as well as chipped ECUs at very reasonable and competitive prices.
Email me for more info. kenji211@tampabay.rr.com
-kenji
Old Jan 31, 2003 | 10:13 AM
eg6ajk's Avatar
b18b is requires a non-vtec ecu such as P75 or PR4 it can be chipped but unless you have cams its pointless to rev the non-vtec to more then 7k rpm
b18c (GSR or R) will work very well with P72 as far as maps but low vtec and rev limit means that you will not be getting the full potentail.
for GSR with dual runner (stock) intake manifold stay with OBDI P72 (USDM specs is by far better then JDM) there are few program avalible but only recommended if you required for larger cams or built built motors.
P28 is an excellent platform for the single butterfly DOHC VTEC motors it offer varitey of programs and its cheap.
for the street JUN, J'S and Superchips are excellent. for racing Mugen/Skunk2/PYR and others which run rich and have few sensors disabled.
user 98292739
Aug 23, 2005 04:42 PM
Turbocoupe97
Aug 15, 2004 11:19 AM
slowassgsxr750
May 4, 2003 03:21 PM
Hondasaurs
Apr 28, 2003 01:47 PM
