'94 Accord EX rear brake Question
Old Jan 31, 2003 | 07:34 AM
RacerBowie's Avatar
Default '94 Accord EX rear brake Question
Hi,
Did a quick search, didn't come up with anything....
Is there anything out of the ordinary about changing rear pads and rotors on a '94 EX?
Any special tools needed, anything unusual? Rotors just slip on like most cars?
Thanks!
Old Jan 31, 2003 | 07:43 AM
urbanlegend21's Avatar
New User
Default Re: '94 Accord EX rear brake Question (RacerBowie)
yes they are rotor over hub, only thing wieird is that the piston has to be screwed back into the caliper, it cannot be pushed
Old Jan 31, 2003 | 07:44 AM
smokin rubber's Avatar
The rear should be pretty easy, but the fronts are hub over rotor.
Old Jan 31, 2003 | 07:45 AM
New User
Default Re: '94 Accord EX rear brake Question (smokin rubber)
you will need an impact screwdriver probably
Old Jan 31, 2003 | 10:38 AM
RacerBowie's Avatar
Default Re: '94 Accord EX rear brake Question (urbanlegend21)
Thanks for the quick answers guys, you saved a co-worker of mine about $500!
Old Jan 31, 2003 | 12:04 PM
95sihb's Avatar
urbanlegand on my 96 accord ex the rear brake piston is the same as the one your talking about. all i used to push the piston back in was a pair of pliers(spell check) it was really easy i just griped on of the groves on the piston and turned and puchedoh yeah turn clockwise(left to right)... i dont think the impact screwdriver would be nesesary(spell check) i cant spell worth sh*t
faran
Mar 30, 2013 07:03 PM
Jerry M.
Jul 23, 2007 10:24 AM
JohnnyEF
Jul 9, 2004 03:12 AM
