Cant remove bolt from caliper? stuck
Old Jan 31, 2003 | 06:09 AM
LOWLIFEHATCH's Avatar
Default Cant remove bolt from caliper? stuck
im trying to change my brake pads right now and I got one done but the other side the bolt wont move at all. What can I do to get it out. I only have hand tools also. Thanks
Old Jan 31, 2003 | 06:10 AM
1BlackHatch's Avatar
Default Re: Cant remove bolt from caliper? stuck (LOWLIFEHATCH)
Which bolt and what caliper?
Old Jan 31, 2003 | 06:11 AM
Default Re: Cant remove bolt from caliper? stuck (1BlackHatch)
the bottom bolt that holds the calipar down. I need to take it off to put new pads in. and its the driver side...
Old Jan 31, 2003 | 06:12 AM
Benson's Avatar
I had the same problem when I changed mine and I had to just keep hitting it till it came loose if U do to choose this way UR palm will hurt like a bitch
Old Jan 31, 2003 | 06:15 AM
Yeah the ones on my LX are kinda stiff. A little WD40 carefully applied to just the bolt and a rubber mallet should loosen it with enough effort.
Old Jan 31, 2003 | 06:18 AM
Run Hatch's Avatar
try to use some WD 40 or try to get some leverage on your rach. good luck
Old Jan 31, 2003 | 06:26 AM
Ehron's Avatar
Liquid Wrench.
Old Jan 31, 2003 | 06:35 AM
well i got the bolt out but the damn thing snapped? is it ok to drive like that? I changed the pads but notice when i went to srew it in part that threads is gone?
Old Jan 31, 2003 | 06:48 AM
nick.na's Avatar
Default Re: Cant remove bolt from caliper? stuck (Ehron)
for liquid wrench...had the same problem...let it soak in there for a little bit and do its job then with a little effort you should be good to go
Old Jan 31, 2003 | 06:51 AM
brcivic411's Avatar
I wouldn't drive it around unless everything is back in place!!!
Old Jan 31, 2003 | 06:53 AM
Default Re: Cant remove bolt from caliper? stuck (brcivic411)
Everythings in place the bolt slides in it just doesnt thread now.
Old Jan 31, 2003 | 06:55 AM
brcivic411's Avatar
You're saying the bolt is there, but it's stripped, so it could just pop out?
Old Jan 31, 2003 | 07:03 AM
basically yea but I put metal expoxy over the bolt to keep it from commng out of the hole. So for now at least it wont fall out while im driving...
Old Jan 31, 2003 | 07:08 AM
kommon_sense's Avatar
Liquid Wrench.
what he said. also, extend the length of your lever to get some leverage.
Old Jan 31, 2003 | 07:26 AM
I would get that taken care of as soon as possible.
Old Jan 31, 2003 | 07:29 AM
will i be able to drill out the bolt or am i gonna need a whoel new calipar? what should i do
Old Jan 31, 2003 | 08:11 AM
greebler's Avatar
junk yard, get a new caliper!! ASAP
Old Jan 31, 2003 | 08:14 AM
BackSideSA's Avatar
Default Re: Cant remove bolt from caliper? stuck (greebler)
Old Jan 31, 2003 | 08:22 AM
Hondasaurs's Avatar
Spray some liquid wrench on it and use a breaker bar.
Old Jan 31, 2003 | 03:21 PM
Default Re: Cant remove bolt from caliper? stuck (ZC_CRX)
yup had to get a new calipar today....120 bucks and damn i thought i would save money by doing my own brakes.......
Old Jan 31, 2003 | 03:27 PM
dwnthehatch's Avatar
I saw this on TV. May be worth a try.
http://www.sears.com/sr/product/summ...id=00952155000
Old Jan 31, 2003 | 04:22 PM
sparq's Avatar
Default Re: Cant remove bolt from caliper? stuck (dwnthehatch)
hehe, little late now that he bought a new caliper...
But dude, if your bolts were messed up anyways, you are better off with newer ones
Old Oct 26, 2003 | 11:31 AM
dyases's Avatar
im having the same problem and i've tried almost everything and it wont come off. tried using leverage, wd-40, and now im worried that im gonna strip the head of the bolt, any other ideas?
Old Oct 26, 2003 | 12:14 PM
miahmouse's Avatar
Default Re: Cant remove bolt from caliper? stuck (dyases)
try taking out the top bolt. (I'm assuming that you're just changing the pads). you'll have to unbolt the brake line (not remove, just unbolt, to get slack in line). and flip caliper the other way...
Old Oct 26, 2003 | 12:15 PM
dyases's Avatar
Default Re: Cant remove bolt from caliper? stuck (miahmouse)
i can't get either bolt to loosen.. and i'm changing the rotor
