What tool to set lsd bearing preload?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i use the ATS lsd tools. kinda tough to tell from the pic, but basically it is a splined shaft that has the axle splines on one side, and a hex head on the other.
NICE!
an inexpensive solution might be to grab a broken axle's endpiece from a salvage yard, then grind a square on the non-splined end to fit a socket onto.
whallah, DIY preload torque wrench setup...
