anybody know the vss in the jdm j1 or s1 tranny?
Old Jan 30, 2003 | 09:07 PM
PhatHardy's Avatar
Default anybody know the vss in the jdm j1 or s1 tranny?
Well I need to know if the integra's with the j1 and s1 tranies had electronic vss or if it was mechanical, cause i just got the gsr cluster in my car(almost complete) and i'mordering my swap this weekend with the j1 or s1 tranny so i don't want to go out and buy the electronic vss, if i'm already goign to get it. Thanks so much guys. oh yeah, if it doesn't come with it, what is the going rate for an electronic vss?
Old Jan 30, 2003 | 09:45 PM
PoS_hYbRiD's Avatar
Default Re: anybody know the vss in the jdm j1 or s1 tranny? (PhatHardy)
both of those trannys are cable opperated and both the s1 and the j1 are mechanical speed sensor .... the only diff in the j1 and s1 is there is a 2 tooth difference on the final drive. i have a j1 in my 89 hatch.
Old Jan 30, 2003 | 09:54 PM
Creamies's Avatar
Default Re: anybody know the vss in the jdm j1 or s1 tranny? (PoS_hYbRiD)
I dont really think it matters on what vss it is. You can run electronic or mechanical. both fit right in my Y1. i had a electronic but i switched to mechanical. I think it matter on the cluster, not the tranny. correct me if i am wrong.
Old Jan 30, 2003 | 09:57 PM
Redline130's Avatar
I got a electronic vss with my jdm S1 and switched over to a mechanical unit. On cable driven speedo's, the speed sensor is in the gauge cluster.
Old Jan 30, 2003 | 10:35 PM
PhatHardy's Avatar
Default Re: anybody know the vss in the jdm j1 or s1 tranny? (cyber13)
so anybody know the going rate for a electronic vss??
Old Jan 31, 2003 | 03:49 AM
Creamies's Avatar
no idea, but if theres a good price given maybe ill part with my electronic one.
Old Jan 31, 2003 | 04:55 AM
ricodemus's Avatar
Default Re: anybody know the vss in the jdm j1 or s1 tranny? (Creamies)
but you are running a gsr cluster, which I uses an electronic VSS. I'm pretty sure that the y1/j1/s1 trannies all used eletronic vss's too. I'd wait until it got here before you go buying anything. You should be fine with what you got.
RACEPAK
Nov 9, 2023 07:24 AM
dannyb18c
May 11, 2012 02:04 PM
^MikeG
Oct 10, 2004 07:00 PM
virginia_dude
25
Feb 1, 2004 06:38 PM
wickedEFguy
Dec 16, 2002 03:51 PM
